Passat b6 No charging !! - Passat b6 no charging the car goes out !!
mehan15 9036 15
Why does my 2006 Passat B6 2.0 TDI stall a few seconds after starting even though the battery shows 12.0 V at rest and about 14.0 V when running?
This is probably not an alternator fault, because when the engine stalls the alternator stops turning and the battery warning light comes on as a result, not the cause [#16368639] With the engine running and loads switched on, about 13.2 V and occasional drops just under 13 V were considered acceptable charging in this thread [#16368653] [#16368686] The replies suggest looking for the real reason the engine cuts out: fuel supply, voltage present where it should be, and other electrical/mechanical faults rather than the alternator itself [#16368639] Several users recommended reading fault codes with VAG/VCDS, since the computer errors may point directly to the cause [#16368748]
  • #1 16368587
    mehan15
    Rate: 32
    Hello, I have a problem with my Passat b6 2006, 2.0tdi. After starting the car after a few seconds, the car goes out and the dashboard battery indicator jumps out, no charging. Auto at rest is 12.00V, and during operation it reaches 14.00V, if the problem can be alternator wear ??
    piotrek22101
    Help: 695
    Rate: 1421
    When the car goes out, the indicator light will be on. There is no charging then. I don't remember how much there should be in this car, but most of it is around 14.5v. Maybe the regulator ends.
    andrzej20001
    Help: 1578
    Rate: 6669
    Goes off Not from the alternator.
  • #4 16368627
    Ricoh_220
    Help: 464
    Rate: 754
    I would be looking for another reason, there could be charging with the engine off. There is no problem here from the alternator current.
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
    yogi009
    Help: 848
    Rate: 2655
    Buddy mehan15 , why the exclamation points in the subject? The engine goes out, after which the alternator does not rotate (because it is not driven from the engine) and the charge indicator begins to burn exactly as before the ignition. Colleagues above are right, the problem is not the lack of charging, visit a mechanic, let him check such small things as fuel supply, the presence of voltage where it is necessary, etc.
  • #6 16368642
    mehan15
    Rate: 32
    if not the alternator, what could be a problem, how can you still check something? I will emphasize that after a dozen or so attempts, the car does not go out and you can move it, I traveled 25km, and it was the same situation at night and in the morning
  • #7 16368653
    Ricoh_220
    Help: 464
    Rate: 754
    After starting the car, turn on the lights and other loads and then measure the voltage on the battery. If you have 14 above 14V then do not look here, you have another problem 100% not charging. If the battery is bad, you won't start it at all. If no charging, the starter will not turn off because it lacks battery power because it is not charged. What you write disables your suspected power failure.
  • #8 16368671
    mehan15
    Rate: 32
    under load I turned on almost everything I could do is 13,20 voltage and sometimes falls under 13v
  • #10 16368703
    mehan15
    Rate: 32
    So I'll be looking for luck and if not, I'm looking for an electrician who will check everything, thank you very much though I know that it is not the alternator's fault
  • #11 16368718
    Ricoh_220
    Help: 464
    Rate: 754
    Maybe the problem was not in electricity you thought about it?
    You should check your computer errors can explain everything itself.
  • #12 16368733
    mehan15
    Rate: 32
    Well, I take everything into account. I have gone through a lot of this passat so nothing will surprise me ;)
  • #14 16368758
    mehan15
    Rate: 32
    thank you very much for help, how to locate the fault let me know what and how. Regards
  • #16 16369082
    patryk44gks
    Help: 11
    Rate: 74
    Quite low, you have this voltage under load, I have altas 140A and after switching on all the lights heating the rear window and seats I have about 14v
The discussion revolves around a 2006 Volkswagen Passat B6 2.0 TDI experiencing issues with the engine stalling shortly after starting, accompanied by a battery indicator light. The owner notes that the battery voltage is 12.00V at rest and reaches 14.00V during operation, raising concerns about potential alternator wear. Responses suggest that the alternator may not be the issue, with recommendations to check for other problems such as fuel supply, electrical connections, and possible computer errors. The owner is advised to seek a mechanic for a thorough diagnosis, including using a VAG diagnostic tool to identify any fault codes.
