[Solved] Mitsubishi Outlander 2010 lift diesel 2.0 air supply (fan) not working
Szary03 14505 2
  • #1 17199198
    Szary03
    The air supply has stopped working, I can not find out which one it is after the fuse instructions? Or maybe someone knows another reason for the lack of airflow. And it happened while driving, I turned on the air conditioning and I felt the smell of burnt insulation and the air supply stopped working. thanks for your help and best regards
    hobbysta5
    Help: 6
    Rate: 18
    The resistor, the blower and the supply air resistor, to be checked.
  • #3 17230205
    Szary03
    Hello. Sorry, I forgot the answer. Yes resistor
    the blower resistor has burned out, which is under the passenger's feet in the background, access is reasonable. But unfortunately the fan motor also fell. I bridged the resistor and it works because it also has a soldered fuse, but it's hard to get it. And the fan had to replace the brushes and the bearing would have to be balanced. I did not feel like it and bought a new one. greetings
