Mitsubishi Outlander - Gets electricity, description of fuses
decybel91 13731 19
What does fuse No. 8 (7.5A) in the Outlander II power, and what can cause its parasitic current draw?
Fuse No. 8 (7.5A) powers the A/C control unit, steering column switches, instrument cluster, ETACS, fuel additive control unit, key warning buzzer, keyless entry unit, power window relay and WCM; on cars after 2009 it also includes lighting control, the alarm sensor and a 7.5A alarm siren [#16695747] If this circuit is drawing current at rest, one reply says the likely cause was an ETACS exchange or reprogramming issue, which also caused the lights to switch on by themselves [#16695969]
  • #1 16695483
    decybel91
    Help: 1024
    Rate: 4234
    outlander II 2.0did from VW.
    Gets about 1.70A at rest.
    1A pulls the radio and amplifiers.
    0.7A draws something that hangs on fuse No. 8 under the board. There is only graphics so weird K in a circle. Identical under fuse No. 5 (10A).
    I care about the description of this fuse No. 8 (7.5A)
    best regards
    leonov
    Help: 1039
    Rate: 2251
    Is this a symbol? Mitsubishi Outlander - Gets electricity, description of fuses
    moto-kord
    Help: 137
    Rate: 505
    Here you are
    Fuse 8 until 2009
    A / C control unit
    Steering column switches
    Universal meter
    Electrical timing and alarm control unit (ETACS)
    Fuel additive control unit
    Key warning buzzer
    Entry control unit without key
    Electrically operated glass relay
    Wireless control module (WCM) 7.5
    After 2009
    Fuse 8
    A / C control unit
    Universal meter
    Key warning buzzer
    Lighting control
    Alarm sensor
    7.5A alarm siren
    Ireneo
    Help: 747
    Rate: 2473
    There was an exchange or reprogram of etacs. Reason for power consumption and sometimes automatic switching on of lights.
  • #5 16696642
    decybel91
    Help: 1024
    Rate: 4234
    Exactly such graphics.
    Thank you very much for the description.
    And this is interesting, because Mitsubishi allegedly was already in the ASO for this problem and the problem has not been resolved.
    best regards
  • #6 16701093
    Ireneo
    Help: 747
    Rate: 2473
    Car from Poland? Was it a reprogram or an exchange?
  • #7 16843992
    sebol_jazda
    Rate: 36
    what was guilty? I have the same problem
  • #8 17631222
    maciejj1231
    Rate: 42
    Hello colleagues
    I recently have an Outlander and 2.2did and also have a problem with power consumption
    good battery, and after a hard time firing the car, the radio is equipped with MMCS navigation -
    stopped working, and the driver's seat also stopped working, please help, electrical diagram
  • #9 17757782
    MarianAgatka
    Rate: 11
    it is a pity that no one writes as looking for I did so
    battery ammeter - 0.35A quiescent current is present
    measurement probe which fuses have voltage and I determined that after removing fuse no. 7 inside the car no power consumption
    without No. 7 is a radio power supply.
  • #10 17758385
    wicio911
    Hello, I have the same problem, I pull out fuse No. 7 and zero power consumption
    Added after 5 [minutes]:
    MarianAgatka did you solve the problem. Or maybe someone has an installation scheme
  • #11 17759565
    maciejj1231
    Rate: 42
    up to this point I also determined this consumption, this fuse from what I remember is also from heating the seats
    and rear view camera?
    this car has the MMCS system with a subwoofer in the trunk and probably an amplifier
    has anyone found out what the exact cause is?
  • #12 17759910
    MarianAgatka
    Rate: 11
    problem solved
    fuse No. 7 according to the scheme I searched for from the radio after disconnecting the radio there is still a power consumption of 0.35A
    but under the radio there is a bluetooth module after unplugging this module, the power consumption drops to 0.03A
    bluetooth driver number 8785a010.
  • #13 17761792
    maciejj1231
    Rate: 42
    the module is responsible for connecting to the phone?
    now something reminds me how the owner of this car said that you can not connect to the phone
    is this the module you have repaired or replaced with a new one?
  • #14 17762084
    MarianAgatka
    Rate: 11
    I drank it, the connector you never used after the case.
  • Asking for the Bluetooth fuse number and parasitic drain source
    #15 19077475
    Wert_1313
    Marian Agatka
    and can you provide the number of this fuse that falls off bluetooth? In my car, something consumes electricity all the time and I do not know what it additionally makes me crazy, the alarm turns on once and someone will not help?
    MarianAgatka wrote:
    I drank it connector, the lady never used it after the case.
  • #16 19077536
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    The F7, F16 above the driver's legs and F31 under the hood are responsible for audio
  • #17 19077539
    Wert_1313
    Cool thanks
  • #18 19774136
    pin987
    I confirm the power consumption, it is best to start checking from the radio, I had it too
    I know that this is a closed topic, but does anyone know what might be wrong with this current-stealing radio?
  • Burned LED bulb caused battery drain
    #19 20041314
    dmb5
    I also had a battery discharge and the reason came from China.
    Android Radio LEDs etc. Bluetooth
    current consumption after turning off the radio support up to 0.7 mA two days battery discharged
    Detached radio alarm - still the same consumption
    after disconnecting the fuse No. 8 15A, the consumption dropped, but I was looking for fuse 8 plugged in and disconnected No. 9 7.5A (interior lighting), consumption after about 30 seconds, maybe a minute fell, I plugged the fuse and started to disconnect the bulbs - with one LED that was burned after unplugging, the consumption decreased. This bulb, when blown, made the system excited and discharging the battery.
    this bulb was the cause
  • #20 20041918
    Wert_1313
    Hi
    For me, the reason for the discharge of the battery was the bluetooth module burned. Disconnecting the module helped.
    Regards
The discussion revolves around the electrical issues faced by Mitsubishi Outlander II owners, particularly concerning power consumption and the function of fuse No. 8 (7.5A). Users report a quiescent current of approximately 1.70A, with specific components drawing power, including the radio, amplifiers, and various control units linked to fuse No. 8. The fuse is associated with the A/C control unit, steering column switches, and alarm systems. Some users have experienced unresolved power drain issues, leading to battery discharge, and have identified the radio and Bluetooth module as potential culprits. Solutions discussed include disconnecting specific fuses and components to reduce power consumption, with particular emphasis on the impact of faulty modules and lighting systems.
TL;DR: Owners report "0.35A quiescent current is present"—a clear parasitic draw that drains batteries. Start by checking radio/Bluetooth and pulling fuses methodically. [Elektroda, MarianAgatka, post #17757782]
Why it matters:** This FAQ helps Mitsubishi Outlander II owners diagnose battery drain fast, identify culprit fuses/modules, and pick effective fixes.
What does fuse No. 8 (7.5A) in the Mitsubishi Outlander II control?
Fuse 8 supplies the A/C control, steering column switches, instrument cluster, ETACS, key buzzer, keyless entry, power window relay, WCM; after 2009 it also feeds lighting control, alarm sensor, and siren. [Elektroda, moto-kord, post #16695747]
How do I quickly check for a parasitic drain on my Outlander?
Put an ammeter in series with the battery, note the resting current, then pull fuses one by one to see when the draw drops. Users isolated a 0.35A draw this way and traced it to the radio circuit. [Elektroda, MarianAgatka, post #17757782]
Which fuses power the radio/MMCS system?
Owners identified F7 and F16 in the cabin fuse box and F31 under the hood as audio power feeds. Pulling these helps confirm radio-related draws. [Elektroda, ptr92, post #19077536]
My draw disappears when I pull F7—what does that indicate?
That points to a load on the radio/MMCS circuit. Several users saw zero power consumption with F7 removed, confirming the audio path as the culprit. [Elektroda, wicio911, post #17758385]
Can the Bluetooth module cause battery drain?
Yes. A failed Bluetooth module (8785A010) under the radio held the circuit awake, causing a 0.35A draw; unplugging dropped it to ~0.03A. “Problem solved.” [Elektroda, MarianAgatka, post #17759910]
Where is the Outlander Bluetooth module and what is its part number?
It sits beneath the radio stack. One confirmed module causing drain carried part number 8785A010. Disconnecting its plug eliminated the excessive draw. [Elektroda, MarianAgatka, post #17759910]
Could interior lighting or LED bulbs trigger a drain?
Yes. A failed LED on the interior lighting circuit (fuse 9, 7.5A) prevented sleep. Removing the bad bulb restored normal current after ~30–60 seconds. [Elektroda, dmb5, post #20041314]
What is ETACS and how does it relate to battery drain?
ETACS is the Electrical Timing and Alarm Control unit. One user cited ETACS reprogramming or replacement as a fix for power consumption and unintended light activation. [Elektroda, Ireneo, post #16695969]
Did Outlander models after 2009 change what’s on fuse 8?
Yes. Post‑2009, fuse 8 also supplies lighting control, alarm sensor, and the alarm siren, expanding potential drain sources on that fuse. [Elektroda, moto-kord, post #16695747]
Why does my alarm randomly trigger while the battery drains?
If fuse 8 feeds your alarm sensor and siren (post‑2009), a fault on that circuit can cause false alarms and parasitic draw. Check loads on fuse 8. [Elektroda, moto-kord, post #16695747]
What resting current have owners measured before and after fixes?
One report showed 0.35A before repair. After unplugging a faulty Bluetooth module, resting current dropped to about 0.03A. [Elektroda, MarianAgatka, post #17759910]
Should I start my diagnosis at the radio/MMCS?
Yes. Multiple owners confirmed battery drain linked to the radio path. “It is best to start checking from the radio.” [Elektroda, pin987, post #19774136]
What is the WCM mentioned on the fuse list?
WCM stands for Wireless Control Module. It manages keyless and immobilizer functions and is listed among fuse 8 consumers. [Elektroda, moto-kord, post #16695747]
How do I isolate a radio-related battery drain (3-step)?
  1. Insert an ammeter in series with the battery and note the draw.
  2. Pull F7 (cabin); if the draw drops, note it.
  3. Continue with related audio fuses to pinpoint the device, then test the Bluetooth module. [Elektroda, MarianAgatka, post #17757782]
Can dealership visits miss this issue?
Yes. One owner reported prior dealer attention without resolution; community tracing later pointed to specific fuse/module faults. [Elektroda, decybel91, post #16696642]
Is there a link between ETACS faults and lights turning on by themselves?
A member noted ETACS exchange or reprogramming as the reason for battery consumption and occasional automatic light activation. [Elektroda, Ireneo, post #16695969]
