[Solved] Philips 32PFL3606H TPM6.1E Chassis: Logo Appears, No Image & Suspected Inverter Transformer Issue
Afkap 3654 2
  • #1 17205980
    Afkap
    The Philips 32PFL3606H turns on, the logo is OK, but after two seconds it turns off, the other circuits work normally. Philips 32PFL3606H TPM6.1E Chassis: Logo Appears, No Image & Suspected Inverter Transformer IssuePhilips 32PFL3606H TPM6.1E Chassis: Logo Appears, No Image & Suspected Inverter Transformer Issue
    I suspect a defective inverter transformer, all the voltages needed for IC Driver are OK.
    Does anyone have any idea where to get it. Thanks for answer.
  • #2 17273679
    STELY
    Rate: 13
    Replace ic801(uba2071at)
  • #3 17301602
    Afkap
    I had to solve the PSU Inverter problem by purchasing a PSU because the inventory transformer could not be purchased.
