Lenovo K6 Note: Charging Issues After Chinese Beach Fan Use, Despite Factory Reset
ptaqx 6585 4
  • #1 17210223
    ptaqx
    Hello, I have a problem with Lenovo k6 Note. The thing is that after connecting the charger there is a signal, a sound, the LED blinks and shows the charging logo but the phone does not charge. I checked on several chargers and cables, it's the same. Strangely enough, the phone slowly but charges from a laptop and quite quickly from the Power Bank. What I have done on my own so far:
    - factory reset,
    - battery change,
    - replacement of the micro usb charging socket.
    Nothing helps.
    The problem probably started after connecting a Chinese beach fan to the charging socket. Is all I have to do is replace the disc or do you have any ideas? I also noticed that the phone is not seen in the computer or laptop (although it is charging), changing the settings of the type of usb connection or "charging", "MTP transfer, etc." gives nothing.) Loads but cannot see.
  • #2 17218416
    actin
    Help: 187
    Rate: 799
    Obvious damage to the data lines, the charger also uses them. Hence the problem with the charger.
  • #3 17218831
    ptaqx
    So the disc to replace?
  • #4 17220732
    TELKAM-COM
    Not necessarily the replacement plate, it is possible that it is enough to fix the bottom plate from loading or replace with a new one without moving the motherboard
  • #5 17220774
    ptaqx
    As I wrote, the USB port plate has already been replaced. I also ordered a ribbon from this plate to the motherboard. We'll see how it will be.
    Unfortunately, changing the ribbon did not help either.
