Black screen - When you turn on the laptop, there is nothing on the screen
Plutoon 6162 3
  • #1 17221121
    Plutoon
    I have a Lenovo laptop.
    When you press the power button, you can hear the laptop turn on. CD-room works. After connecting to the TV with the HDMI cable, the image appears on the TV. This is the only way to see the screen. The toutch pad works like the rest.
  • #2 17221125
    daminek1234
    Help: 61
    Rate: 88
    Damaged ribbon / die.
  • #3 17221321
    Huczul011
    Rate: 10
    Or the artwork fell, if you have a guarantee, give it back to it, or for service. Such a matrix replacement may cost from PLN 50 to PLN 200.
  • #4 17221354
    injured
    The image display is set to an external screen only.
    Try to switch to the main screen by pressing Fn + F10, or if the function keys are on, the same F10.
