Peugeot RCZ 1.6 THP 156 HP Timing Replacement: Modernized Parts & Repair Options
Robguz8354 11166 6
  • #1 17228388
    Robguz8354
    I would like to know what the current issue looks like when replacing the timing belt. Have these parts actually been modernized? Do you know anything about the fact that after replacing the full timing belt, it is quiet for a long time? I only read on the Internet that after the repair, the problem returns. The fact that most are old posts.
    You can also read that we can easily find an independent car repair shop that will undertake the repair. Four mechanics have already refused me (even those who specialize in repairing French cars) saying that they do not repair the timing chain in these engines.
    What is the case when a Peugeot is repaired in a Citroen service, can I count on "age promotion" in this case?
  • #2 17229716
    paszczakq
    Help: 48
    Rate: 204
    There, in addition to the timing, there are other flowers in the engine regarding the variable valve lift.
  • #3 17229766
    Robguz8354
    As long as the engine is cold it clatters. Nothing else is happening so far. On the website, they advised to come only when errors about misfiring start popping up ...
  • #4 17229788
    paszczakq
    Help: 48
    Rate: 204
    Change the service, because such problems may be too late.
  • #5 17230178
    Robguz8354
    Despite the fact that they advise this, I still want to have the car serviced. The same, although the approach is strange. Just what do I do when every other mechanic refuses to take on it.
    What else could be repaired apart from the timing? I don't want to argue that it will be it, I say so based on the opinion of the mechanics who had a chance to hear it.
    They haven't had such a possibility on the website yet because when I get there, the engine is already warm. Before the repair, I'll leave it overnight for them to check.
  • #6 17230242
    paszczakq
    Help: 48
    Rate: 204
    Likes the valve seat to fall out or burn out.
  • #7 17230411
    Robguz8354
    And what symptoms if it were?
The discussion revolves around the timing belt replacement for the Peugeot RCZ 1.6 THP 156 HP engine. Users express concerns about the reliability of modernized parts, noting that issues may return after replacement. Mechanics have been hesitant to undertake repairs, particularly regarding the timing chain, leading to frustration for the owner. There are mentions of other potential engine issues, such as variable valve lift problems and valve seat failures. The owner is considering having the car serviced at a Citroen service center, questioning whether this would provide better results due to the age of the vehicle.
