[Solved] Peugeot 308 1.6 THP - Timing Chain Synchronization Error at 58K Miles, Replaced at 31K Miles
Bartol tech 11664 4
  • #1 17054972
    Bartol tech
    Rate: 40
    Hello, the mileage of the car is 58 thousand, it crashes the synchronization error of the top with the bottom, the timing has already been replaced under the warranty at 31 thousand. The question is whether he stretched again or changed.
  • #2 17055007
    Samuraj
    Help: 286
    Rate: 619
    Unfortunately, such a problem with these engines. I have 110,000 loaded and the chain has been replaced 3 times.
  • #3 17064783
    komandospolen
    Welcome. in this case it may not be a new chain but a sprocket because, if both parts are worn, why is only the chain replaced?
    I had the same problem as everyone else, I went to the mechanic and got Zje ... decent, because not only the chain changes in this engine, but also the sprockets, without it there is always a difference and in this way everything can be finished. and if you calculate, 3 times the exchange is adequate to exchange everything properly without stress and problems and a few pennies remain :P
  • #4 17067701
    Bartol tech
    Rate: 40
    Well, a job awaits me
  • #5 17583164
    Bartol tech
    Rate: 40
    After the problem, the wheels of the lock shafts were re-set and the guitar changed
