[Solved] Xiaomi Redmi Note 4x Touch Issue: Self-Clicking, Bottom Keys Malfunction, & Solutions
blahfff 7668 1
  • #1 17233417
    blahfff
    Help: 1036
    Rate: 1301
    Xiaomi Redmi Note 4x - very good condition, nothing bruised or broken, basically like new. It works in general, but when turned on, the touch goes crazy and "clicks" itself. Generally, it looks as if the bottom function keys are pressing themselves. The plate is clean, no traces of moisture, corrosion. After detaching the touch, it is calm and when the touch is connected back on the phone, it is normal for a moment. After attaching another touch for a short time, the phone behaves the same. To be sure, the uploaded soft - still the same.
    Some other concept, maybe it's some known problem in this model?
    // Update:
    At the probe, I detached the touch from the display and the function keys flicked even a few millimeters above, somewhere in the air. For some reason they are feeling too. On another touch hooked up briefly, this time everything was ok and after 2 days of testing, no miracles were working. After replacing the touch, the phone works properly. Some miracles that org touch in perfect condition until it started to freak out.
  • Touch panel replacement fixed phantom key presses
    #2 17264134
    blahfff
    Help: 1036
    Rate: 1301
