Citroen C3 I 2002 1.4 Benz 8V: Locating Hole in Block for Crankshaft/Flywheel Blocking
Citroenc32002 8862 4
  • #1 17235881
    Citroenc32002
    I am asking for help in locating the hole in the block for blocking the crankshaft / flywheel in the Citroen 1.4 8v petrol engine KFV designation, despite the fact that the topic appeared on the forum, I cannot locate the place of blocking the shaft. The head was removed after the timing jumped and now I have a problem how to properly set it, thanks for the answer
  • #2 17236077
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    There should be a hole of 6 or 6.5.
    In front of the engine.
  • #3 17236207
    Citroenc32002
    I need specific advice because it should be I know
  • #4 17236444
    mario 77
    Help: 66
    Rate: 335
    The flywheel above the oil filter is locked. According to the procedure, remove the oil filter.
  • #5 17236908
    milejow
    Help: 1563
    Rate: 5149
    The place of blocking is marked in red, probably a 7mm pin, I don't remember.
    Działalność własna
    Mętów 99, Lublin, 20-388
