Xiaomi Mi Max - Damaged screen - copying data from the phone's memory
makitamc 23484 6
  • #1 17237813
    makitamc
    A few days ago I damaged the screen on my phone, I would like to copy all the data to my computer.
    -The phone is turned on.
    -Touch works.
    -You can`t see anything on the screen.
    -I have debug mode turned off*
    How can I do this? Please help!
  • #2 17238055
    procsa
    Help: 173
    Rate: 364
    It`s hard for me to see it, if you don`t "blindly" hit "share files" after connecting the USB, because it appears in the USB connection, then only programs like "Dr fone wondershare" remain.
  • #3 17238821
    blahfff
    Help: 1036
    Rate: 1301
    There aren`t many options. If you have debugging turned on and the phone was authorized with the computer you are using, you can download the files using adb pull or the total commander plug-in, or use scrcpy (downloadable on xda or github) to view and control the phone through the application. If it was not authorized, you are left to blindly hit the authorization option or at least the option to allow the MTP connection to be able to copy the photos. Very difficult in case of set lock code etc.
    HDMI starts because the phone does not support it. In the case of an unlocked bootloader, you could try to flash TWRP blindly and hope that it will be able to decrypt the internal memory (unless you used any screen lock).
    Apps like "dr fone wondershare" and others of this type can be skipped because they are just a scam. Data recovery from memory sticks is also basically impossible due to factory-enabled encryption, so basically, if the first two options do not work, the only reasonable alternative is to move the display, at least for a moment, to save the data.
  • #4 17239000
    makitamc
    I have no idea how to do it, I tried to find it after connecting it to the computer, but it`s almost impossible.
    It`s not worth buying a new display, I`m not sure if something else is damaged inside (it`s bent a bit) :)
    Can someone send me a photo where this message is displayed after connecting to the computer?
  • #5 17239083
    blahfff
    Help: 1036
    Rate: 1301
    First of all, did you have any code, drawing or pin set? Secondly, after connecting to the computer, it is detected as ADB and after the comment "adb devices" something is displayed?
  • #6 17239161
    makitamc
    Unlocks with a fingerprint. I do not have USB Debugging mode enabled.
    Added after 28 [minutes]:
    (c) 2017 Microsoft Corporation. All rights reserved.
    C:\WINDOWS\system32>adb devices
    List of devices attached
    * daemon not running. starting it now on port 5037 *
    * daemon started successfully *
  • #7 17241542
    blahfff
    Help: 1036
    Rate: 1301
    Hmm, I think you wrote earlier in the first post that you had debugging turned on. Never mind. There are not many options and you obviously don`t care that much about the data since you immediately reject the option of ordering or exchanging the set.
    I don`t have Mi Mix, but in Note 4x the option to select the USB mode looks like in the attachments.
    After connecting, first information appears at the top of the screen (second attachment) and after clicking on it, at the bottom of the list with a selection (first attachment). The second option is the one you are interested in. If you haven`t restarted your phone yet, unlock it with your finger, connect it to the computer and try blindly. If you restarted, you will have to enter the code/PIN/picture first.
    • Xiaomi Mi Max - Damaged screen - copying data from the phone's memory IMG_20180526_125120.jpg (2.35 MB) You must be logged in to download this attachment.
    • Xiaomi Mi Max - Damaged screen - copying data from the phone's memory IMG_20180526_125116.jpg (2.03 MB) You must be logged in to download this attachment.
The user seeks assistance in transferring data from a Xiaomi Mi Max with a damaged screen. The phone is operational, but the display is non-functional, and USB debugging is disabled. Suggestions include using ADB commands if the device is authorized, or attempting to blindly select the MTP connection after connecting to a computer. Alternatives like "Dr. Fone Wondershare" are deemed ineffective. The user expresses difficulty in navigating the connection options and is uncertain about the internal condition of the device. The discussion highlights the challenges of data recovery without debugging enabled and the potential need for a screen replacement if data recovery fails.
