[Solved] Philips 32PFH5300/88 TV: Troubleshooting Screen Message & Software Update Issues
tomgraw 14364 14
How can I get rid of the warning message on my Philips 32PFH5300/88 TV after a failed software update?
The message is a browser security warning about a website without an SSL certificate, not a TV fault or virus, so the TV itself is OK [#17243009] If it keeps appearing, change the browser start page in the TV’s browser settings [#17259996] Also check that the TV has the correct date and time, because wrong time settings can trigger certificate warnings [#17259848] If needed, avoid suspicious sites or disconnect the TV from the Internet to stop the prompt [#17246478]
  • #1 17241251
    tomgraw
    I have a Philips 32PFH5300 / 88 TV set
    for some time there is a message like in the picture
    I was doing a software update, it didn't work
    Can you advise something?
  • #2 17241307
    zadam64
    Help: 552
    Rate: 738
    Hello. Go to the Philips website - technical support, specify the problem of the TV after registering the product, describe the problem in detail, I believe that the TV is infected and the need for a thorough reset to factory values. A lot of work.
  • #3 17241336
    tomgraw
    Thank you very much for the advice
    I'm already on my way :)
    I will write what and how it went
    best regards
  • #4 17243009
    Polon_us
    Help: 1184
    Rate: 1280
    zadam64 wrote:
    determine the problem of the TV ...
    Eeeee ...
    zadam64 wrote:
    I think the TV is infected ...
    Eeeee ...
    No eggs, sorry :)
    After all, the message shown on the TV screen does not apply to him.
    It is only a warning that the given website does not have an SSL certificate.
    The TV "politely" asks if it should continue using the site.
    It is not a damage to the TV or a virus infection.
    The author of the topic can rest easy.
    The TV is ok.
  • #5 17244317
    zadam64
    Help: 552
    Rate: 738
    Hello. Well, watch only. Good luck :shii:
  • #6 17245759
    Polon_us
    Help: 1184
    Rate: 1280
    zadam64 wrote:
    Hello. Just watch it.
    Yaaah ....
    And no comments about your previous statement?
    So authoritative?
    I "admire" people with such well-being ... heh ...
  • #7 17245904
    mblazynski
    Help: 18
    Rate: 23
    I confirm.
  • SSL warning is not a TV fault
    #8 17246316
    zadam64
    Help: 552
    Rate: 738
    I confirm.
    I would like such a message to be displayed on your TV, e.g. while watching the World Cup.
    Moderated By Olek II:
    3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
    3.1.8. Do not link to material that contains viruses, illegal or harmful software.
    #9 17246478
    DiZMar
    Help: 2891
    Rate: 6646
    I confirm.
    Do not select "suspicious" sites on Smart TV, preferably disconnect the Internet from the TV and this message will not be there.
  • #10 17246503
    barteksmrek
    Help: 89
    Rate: 224
    Why should my colleague smart disconnect from the Internet? Set a different start page in your browser. By the way, google is safe.
  • #11 17246532
    LeDy
    Help: 1990
    Rate: 2937
    Not only that you gave a "spot", but you go further, wondering about the championship,
    instead of bashing my own ... breasts ???
  • #12 17248213
    mblazynski
    Help: 18
    Rate: 23
    It is sick that these smart TVs display such messages while watching TV. If I use the Internet, I understand this information. Apparently our smart TVs are doing something in the background, hence the effect.
  • #13 17259747
    tomgraw
    Hey
    because now I don't know anything :(
    I am connected to the internet because I want it to be connected
    a simple question: how to remove this message ?? if I had a mouse, maybe I would click, but I don't (I'll tell you that the computer mouse doesn't work, or I can't run it)
    I use TV (or rather my child) but this message on every station is ......
    any specific idea how to approve it (change the start page as someone wrote, but how?)?
  • #14 17259848
    g107r
    Help: 811
    Rate: 993
    Do you have the correct date and time on your TV?
    I saw such messages about outdated security several times when the computer "was" after a bios reset in eg 2009, and the website presented a certificate from 2017.
    After that, what are these pages? Maybe they do have suspicious security features?
  • #15 17259996
    barteksmrek
    Help: 89
    Rate: 224
    You can change the start page in your browser settings.
The discussion revolves around troubleshooting issues with the Philips 32PFH5300/88 TV, specifically concerning a persistent screen message following a failed software update. Users suggest contacting Philips technical support for a factory reset and clarifying that the message may not indicate a virus but rather a warning about SSL certificate issues on a website. Recommendations include ensuring the TV's date and time are correct, changing the browser's start page, and avoiding suspicious websites. The original poster seeks a solution to remove the message, expressing frustration over its constant appearance during TV usage.
TL;DR: 32PFH5300/88 owners: 1 persistent on‑screen prompt is usually an SSL certificate warning, not malware. "It is only a warning that the given website does not have an SSL certificate." Fix by approving, changing the browser’s start page, or correcting date/time. [Elektroda, Polon_us, post #17243009]
Why it matters: This FAQ helps Philips 32PFH5300/88 owners fix a recurring security prompt that blocks viewing or Smart TV browsing.
What does the certificate/security message on my Philips 32PFH5300/88 mean?
Your TV’s browser warns that the site lacks a valid SSL certificate. The TV asks whether to continue. It is not a TV fault or malware. "It is only a warning that the given website does not have an SSL certificate." Dismiss it, or avoid that page. [Elektroda, Polon_us, post #17243009]
Is my Philips TV infected or damaged because of this pop-up?
No. The message concerns the website, not the TV. The set is fine. Continue only if you trust the content. The prompt is a standard SSL warning, not a virus. [Elektroda, Polon_us, post #17243009]
Why does the message appear even while I watch regular TV channels?
Smart features can load web elements in the background. That can surface a browser certificate prompt during TV viewing. "Apparently our smart TVs are doing something in the background." To stop it, change the browser start page or disconnect Internet. [Elektroda, mblazynski, post #17248213]
How do I stop the warning from coming back at startup?
Set a safe browser start page. How-To:
  1. Open the TV’s Browser app.
  2. Open Settings and locate Start page or Home page.
  3. Set it to a trusted HTTPS site or Blank. This prevents the browser from opening an insecure site on boot. [Elektroda, barteksmrek, post #17259996]
What homepage should I use to avoid the warning?
Set a trusted HTTPS page, like Google. "By the way, google is safe." Using a secure homepage stops repeated prompts from insecure start pages. [Elektroda, barteksmrek, post #17246503]
Should I just ignore the warning and continue to the site?
Proceed only for non-sensitive viewing. Do not enter passwords or payment details on HTTP or certificate‑error pages. Use trusted services and apps instead. This reduces risk from eavesdropping on insecure connections. [Mozilla, 2023]
Will a software update or firmware upgrade remove this message?
No. A TV update cannot fix a website’s certificate. The warning is about that site’s security, not TV software. Updates are still useful for features and stability. [Elektroda, Polon_us, post #17243009]
Can wrong date or time cause these certificate warnings?
Yes. Certificate validity depends on accurate device time. One user saw warnings with device time set to 2009 against a 2017 certificate. Edge case: after a reset or power loss, the clock can drift. Correct time to resolve mismatches. [Elektroda, g107r, post #17259848]
What if my browser has no option to change the start page?
Disconnect the Internet from the TV to stop the prompts. This prevents background pages from loading. You lose Smart TV features while offline. Reconnect after you finish watching. [Elektroda, DiZMar, post #17246478]
The message shows on every channel—what should I try first?
Change the browser’s start page to a secure site. This prevents the certificate prompt from loading at startup. It is a fast, reversible change. [Elektroda, barteksmrek, post #17259996]
Who should I contact at Philips if I still need help?
Use Philips Technical Support. Register your product, describe the issue, and request guidance. Support can walk you through resets if necessary. [Elektroda, zadam64, post #17241307]
How common is HTTPS today, and why do TVs warn so often?
Approx. 95% of Chrome page loads use HTTPS, so certificate checks are routine. TVs warn when pages fail those checks. This behavior protects you from insecure sites. [Google, 2024]
