Philips 24PHH4000/88 TV: CI Plus Key Fail Message & HDMI 1 Image Issue - Solutions Needed
AdrainM 11796 3
  • CI Plus key fail and HDMI 1 no signal
    #1 16599268
    AdrainM
    Hello, I have a strange problem, I am "green" in these cases and please do not pick on :)
    Well, when I started the TV this morning, the words CI Plus Key Fail appeared in the upper left corner ...
    I don't know what's going on but I'm terribly nervous.
    The TV was used as a monitor for PC and ps4.
    I think after this message, when I try to switch to HDMI 1, I do not catch the image from the console at all.
    I don't know if it is this fault but I decided to write about it.
    Tried to reset the tv and nothing.
    Thank you in advance for the answer :D [/ B]
  • #2 16599359
    mirex
    Help: 1950
    Rate: 1990
    We are pleased that you decided to write about it.
    Maybe now decide to read about it?
    There is a place at the top of the main page of the section, type CI Plus Key Fail there.
    Or, on the top bar, click "search". ;)
  • #3 16600355
    AdrainM
    I've already read a bit about it, but there's not much of it. I know that it is something with the CI input, but why it appears, I do not know. And I have no idea how to get rid of it.
  • #4 16600671
    mirex
    Help: 1950
    Rate: 1990
    After all, it is written in the forum how to get rid of it. ;)
    So apparently you haven't read. And there is actually not much. Because why repeat the same thing over and over again?
