Thermomix TM5 USA 110V to 220V - USA 110V to 220V converter selection
maxim440 10245 5
  • #1 17243959
    maxim440
    Can anyone tell me if the Thermomix TM5 US version 110V will work properly by connecting it with the following Converter / voltage reducer:
    Converter - autotransformer parameters:
    Input voltage : 220V - 240V
    Output voltage: 110V - 120V
    Nominal power: 2000 W (current 16.4A)
    Thermomix USA Specification:
    Motor: Maintenance-free Vorwerk reluctance motor 500W rated power
    Heating system: 1,000W power consumption. Protected against overheating.
    Connected load: Only for 110V 50/60Hz (TM5-4)
    Maximum power consumption 1400W
    I don't know anything about it, can you help me please? For example, will it have a predictable current consumption at start-up and you need to buy a transformer with a higher power?
    I will be grateful for any help!
    Regards
  • #2 17244125
    oldking
    Help: 162
    Rate: 524
    He should give it a rest. Even if the power consumption is higher at the start, the transformer should be able to withstand it without any problems. You have 600 watts anyway.
    The assumption that it is an autotransformer and not some Chinese converter.
  • #3 17245853
    maxim440
    Thank you very much for your answer. Will one with a soft start be suitable: Link 1 ? or better something like this: Link 2 ? the latter is the price of 2x, although both are probably made in China because on several pages they were under the names of other brands, but the appearance is the same.
  • #4 17245915
    oldking
    Help: 162
    Rate: 524
    If you have the money, take the other one, a company known for the production of transformers is probably not a dud.
  • #5 17840419
    Felix5591
    I use Transformator ELC T-2000 Step Up & Down Transformer and I am satisfied, I used this device both in the USA (I had a Thermomix TM31 from Poland), now I use it in Poland with a TM5 device from the USA.
  • #6 18501652
    KateKeter1988
    Rate: 18
    Hello, did any of you send thermomix from Poland to the USA? Can I get some practical advice on this topic?
