Vorwerk Thermomix Heating Issue: No Temperature Display, Not Lighting Up, Clicking Sound
McRancor 43634 10
Why does a Thermomix not heat up and not light the temperature display after turning the knob?
The Thermomix may not heat if you have not first set the operating time on the display, and dirty contacts between the bowl and the base can also stop heating. One reply says the unit only heats after the time is set [#3719354] Another reports that cleaning the contacts between the pot and the device restored heating after the machine had seemed dead for months [#15667533] If those simple checks do not help, one user was advised by service that the vessel/heater assembly itself may be faulty and need replacement [#15355789]
  • #1 2090731
    McRancor
    Help: 479
    Rate: 124
    Hello!
    I have a problem with a well-known and popular device, namely it has stopped heating.
    After turning the knob, the scale does not light up and of course it does not give the temperature ...
    I got the contraption turned on, but everything looks nice.
    The device paused a bit and then clicked once, heated up beautifully, but now the hatch again.
    Maybe someone repaired a similar fault, or at least saw a service shop?
    Any advice and suggestions are welcome :)
  • #2 3665288
    m626
    Help: 14
    Rate: 41
    I have a similar problem. VORWERK type Thermomix 21 / 2-1 - does not heat up. Heater OK, switching system - optocoupler and triac - OK, temperature sensor OK. How to check the rest without a schematic? Processor, memory, soft? Maybe I missed something?
    I join the request for any suggestions.
  • #3 3665552
    McRancor
    Help: 479
    Rate: 124
    For me, it turned out that an operating error is to blame ;) I don't remember exactly what I was doing wrong, but the device was not damaged.
  • #4 3719354
    Eljot
    Help: 7
    Rate: 17
    My friend had a similar problem, but he forgot that in order for the Thermomix to heat up, you first need to set the operating time on the display.
  • #5 8792725
    yanik44
    Rate: 31
    Gentlemen, I have another problem with the thermomix, namely, when turned on, it heats up to the maximum all the time. what could I check inside what's wrong with him?
  • #6 8794893
    McRancor
    Help: 479
    Rate: 124
    Check that the triac is not compacted and that it is getting proper control.
  • #7 9970659
    prince12
    yanik44 have you solved the problem?
    I have the same problem
  • #8 11500828
    marcin termol
    if it heats up all the time, it is a replacement control panel, if you have a thermol 21/1, it's not a problem, costs just a penny, and as 21/2, there are costs almost PLN 500. other order does not heat up
  • #9 11836774
    sneak
    Help: 5
    Rate: 28
    Hello !
    I have described my problem here too.
    I have a Thermomix from Vortwerk. The device seems to work properly, but the engine has no power, you can stop it with your hand and the engine becomes stupid. Everything looks fine on the control board. The transistors have no short circuits, and the electrolytes look OK too. The freezer didn't help either.
    What could be the reason? Will I find a schematic of the device somewhere?
  • Thermomix TM31 vessel replacement restored heating
    #10 15355789
    kwitek255
    Hello, I also had a problem with the thermomix model 31, I called the service in Krakow, a very nice gentleman asked me to borrow a vessel from my friends because there was probably a problem here (he fell several times) and after replacing the vessel, everything is ok.
    Regards
    Added after 2 [hours] 20 [minutes]:
    I also bought a new one because, unfortunately, as I was told in the service, the heater is welding inside the vessel and nothing can be done with the old one, you have to buy a new one. The cost of a new one without the knife cover and stand is PLN 349 today.
  • #11 15667533
    zarek1988
    Beloved mine. For posterity, because you will probably look more than once what is the reason for the lack of heating. And the matter is trivial. Clean the contacts between the pot and the device. My Thermomix stopped being dusty for half a year before I started working on it because I thought it was damaged. The contacts I had, I asked dirty and did not want to heat. Regards
The discussion revolves around a heating issue with the Vorwerk Thermomix, where users report problems such as the device not heating, the temperature display not lighting up, and unusual clicking sounds. Several users share their experiences, suggesting potential causes and solutions. Common troubleshooting steps include checking the operating time setting, ensuring clean contacts between the pot and the device, and verifying the functionality of components like the triac and control panel. Some users mention that operational errors or dirty contacts can lead to the device not heating properly. In one case, a user had to replace the vessel due to internal welding of the heater. Overall, the conversation highlights various diagnostic approaches and solutions for Thermomix heating issues.
