[Solved] Hyundai Sonata 2.0 CRDi: Persistent P2002 Error Post-DPF Filter Cleaning & Sensor Queries
dzakub88 19947 5
  • #1 17255426
    dzakub88
    Rate: 9
    Hello, I have the following problem. The car jumped into safe mode after connecting to the computer error P2002 low efficiency of the DPF filter. I must point out that after turning off the car, the error disappears. The error popped up only when overtaking the car, e.g. longer driving above 3,000 revolutions.
    I decided to clean the filter in a professional machine, they give a 2-year warranty. After cleaning, the car regained power and everything seemed fine. As a precaution, after a more aggressive ride, I connected the computer again and again the P2002 error. This time, without emergency mode, after cleaning, I have driven maybe 500 km. The service cleared all settings, i.e. the amount of ash, soot. I don't know what the problem could be. Theoretically, it is a simple system: filter, temperature sensor, differential pressure sensor. What could be the symptoms of a damaged pressure sensor? If the filter were still clogged, shouldn't the error pop up all the time?
  • #2 17581366
    martekbr
    Did my colleague solve the problem because I have recently had the same problem. I, in turn, replaced the DPF with a new one and after replacing and erasing the gr. Soot appears on P2002.
  • #3 17583220
    dzakub88
    Rate: 9
    I replaced the differential pressure sensor, then resetting its settings and it helped. I bought a used one, because it is new only on the Hyundai website and they wanted 800 PLN
  • #4 17587073
    martekbr
    Thanks for the answer, I also replaced the differential with a stimulant, but the setup specialist probably gave the body because it's still P2002. I will go to another one again and have it try to set it up again. Thanks again.
  • #5 17587112
    andrzej20001
    Help: 1578
    Rate: 6669
    Access hoses?
  • #6 17588717
    dzakub88
    Rate: 9
    DPF differential pressure sensor replaced, then its reset in the ECU.
