[Solved] Yaris 2010 P2463 DPF - After cleaning the DPF, it continues to display error P24
trydzews 47907 5
  • #1 17604371
    trydzews
    Rate: 23
    Should any adaptation procedure be performed after cleaning the DPF in Toyota Yaris 1.4 D4D 2010?
    Currently, the DPF is washed out, free and the problem is with the recurring P2463 error.
    How can I get rid of it ??
  • #2 17604483
    Launch78
    Help: 22
    Rate: 162
    you have to reset the differential sensor with the tester, or the firing procedure will not let you go
  • #3 17604484
    seraf91
    Rate: 14
    Filter zeros? Exchange for a new one?
    Maybe these types of commands were made?
    P2463 is related to soot build-up? If so, resetting should help.
  • #4 17608069
    ireneusz1981
    Level 19  
    Help: 26
    Rate: 82
    It would be best to connect a service computer because it has the greatest diagnostic capabilities and in the area of DPF filter service, see what we have available. Maybe kts or delfi will cover it, but it will be known after connecting. It would be necessary to calibrate the differential pressure sensor or it is best to program / save the filter replacement. When it reads that it has a new (clean) installed, the filling level will be reset and the error will disappear. Only the instructions for replacement or adaptation should be followed (as it says that the procedure will be possible after meeting the conditions, it must have these real conditions for the procedure to be successful.
  • #5 17641577
    trydzews
    Rate: 23
    Exactly, the software DPF cleaning routine did the trick.
  • #6 17641580
    trydzews
    Rate: 23
    Added after 31 [seconds]:
    Problem solved.
