Fuel Float Issue in Audi A4 B5: Tear-off Contacts, Electrical Conductivity & Solutions
Anka.1981k 13746 5
  • #1 16659074
    Anka.1981k
    Fuel Float Issue in Audi A4 B5: Tear-off Contacts, Electrical Conductivity & Solutions Hello. I have a problem with a fuel float. Initially, I thought something was hanging up. Today I pulled out the float and everything is ok, except nwm what a driver or what. It seems to me that it has tear-off contacts and therefore it does not conduct electricity and does not work. I attach a picture because now I do not know if it's the fault that it is wiped or maybe something else. I would like to say that this is the part that is attached to 2 cables and the float hovers and falls just touches this "driver" Thank you in advance for hints because now I know whether I should buy a new swimmer or maybe some other reason. Greetings. Fuel Float Issue in Audi A4 B5: Tear-off Contacts, Electrical Conductivity & Solutions
  • #2 16659354
    ArtXs
    Help: 93
    Rate: 112
    In the picture from this angle it is difficult to tell if the metal is damaged or only dirty.
    Here is described together with photographs how to perform cleaning link . It will not hurt to screw up.
  • #3 16659696
    Anka.1981k
    Thank you for the information, but the metal is all peeled and not dirty. Unfortunately, this sensor to replace rather because nothing will be done with it. My was clean, as I took it out and not as dirty as in the attached link. Even though it was clean, it can be seen that it is completely obliterated and does not conduct as it should :( Nevertheless, thank you for your help. greetings :)
  • 8D0919673N fuel level sender replacement needed
    #4 16659848
    januszx3
    Help: 214
    Rate: 420
    Anka.1981k wrote:
    I attach a photo because now I do not know if it's the fault that it is sacked or maybe something else
    You presented the fuel level sensor, "Audi A4 B5 1.9 TDI In Tank Diesel Fuel Level Sensor Sender Unit - 8D0919673N", with a smoothed conductive path, ... and no replacement for efficient, unless you can not cope ... there are DIY methods ... but for that you probably will not reach. Needed part, it has a factory identification number - 8D0919673N
  • Passat fuel sender may fit with different plug
    #5 16660947
    Anka.1981k
    Well, I'm looking everywhere and there is not :( (((I found 1 item all swimmer but so dirty and cry PLN 199 with pity talk even. Now I wonder whether the passat would not fit, although it has a different plug but otherwise seems similar, although it seems to me that it is a bit shorter; (now I do not know what to do because I've probably already sought what I could, I called where I could and a little bit of it (like such a shit and you can not get it) (But thank you for your help and best regards :)
  • #6 17519707
    zamela
    Rate: 55
    I also have a problem with the plate on which the contacts are moving.
    After cleaning and viewing the element under the microscope, you can see that the plates are wiped, which gives the effect of fiddling a hint from the fuel level.
    I saw on the net a complete swimmer for 700 PLN - the price is killing but I have a question whether the tile is separate? because she is using up.
