Ariva 4K COMBO Decoder: Issues with Channel List Update and Restart Failure
majkovski 3708 2
  • #1 17166387
    majkovski
    I recently bought the above-mentioned decoder.
    When trying to upload a new channel list as described
    http://wiki.ferguson.pl/pl/Jak_wgrał_listę_programów_z_Enigma_2%3F ,,
    The decoder restarted and stopped working, i.e. after turning on the power, the LED flashes red and nothing else.
    Resuscitation attempts by this
    http://wiki.ferguson.pl/pl/Serwisowe_wgwanie_oprogramowania
    - do not give anything
    Please advice what to do to effectively resuscitate him ??
    Is it possible to program it via jtag?
    Thank you in advance for your response.
  • #2 17176351
    LeDy
    Help: 1992
    Rate: 2940
    Register, read. http://plff.webd.pl/plff/forum/showthread.php?tid=13516&page=3
    Ferguson "forgot" to mention it.
    Differences in Amlogic S905 processors.
    Ariva 4k / combo has Amlogic S905-B processor, Quad core Cortex A53 @ 2.02 GHz. The KI and KII PRO tuners have the "legacy" Amlogic S905 processors.
    It is the same, but there are differences. X is A, B, C, D ..... H.
    Where did you upload this list from?
    I read somewhere that the list should be without a landline.
  • #3 17177997
    majkovski
    Thank you for your answer, but I've already found a solution to the problem ;)
    The topic can be closed - flash to the dedoder can be uploaded in 2 ways.
    I had a good image - I know about the differences between processors.
    Amlogic Burn Card Maker or Amlogic USB Burning Tool - male usb - male usb cable there are pins on the motherboard.
    Best regards,
    Majk
