[Solved] Philips PowerPro Aqua 3in1 vacuum cleaner - yellow LED is on, not charging - wha
emeryt 1947 13419 3
  • #1 17279611
    emeryt 1947
    Philips PowerPro Aqua 3in1 cordless vacuum cleaner - the red LED was always on when the battery was discharged, and after charging, three green LEDs were on. Now the flashing yellow LED is on, the vacuum cleaner is only half a year old, or someone had a similar case.
    best regards
  • #2 17279710
    bubu1769
    Help: 1177
    Rate: 2374
    If you have a proof of purchase from him, give it back for warranty.
  • #3 17279739
    Sniezynka
    Help: 199
    Rate: 841
    Such signaling means that the battery cannot be charged.
  • #4 17320298
    emeryt 1947
    I returned the vacuum cleaner to the store as part of the complaint, the waiting time is about 3 to 4 weeks.
    I think the problem will be resolved.
    Greetings to all electrode users and thank you for the advice.
