Dyson V6 - Flashing red light while charging, cell measurements
pancyk 19863 10
Why does a Dyson V6 flash a red light while charging even though the 6 Li-ion cells measure normal voltages, and is the fault in the cells or the electronics?
The flashing red light in this case is most likely a fault in the battery electronics/control board rather than exhausted cells. Even after the cells were discharged to 3.6 V each, the same red flashing remained, and the output stayed below the nominal 21.6 V, which points away from the cells and toward the board [#17885720][#17886932] One reply also noted that if the charger voltage is lower than the battery voltage, it cannot charge, and that the charger must be the original Dyson unit [#17885459][#19833200] If the charger is original, the practical fix suggested is to replace the electronics/controller board, which can be bought as a replacement on AliExpress/eBay/Banggood [#19833200][#19833165] When buying a replacement, pay attention to whether it has a balancer and whether it matches the switch version [#19833165]
  • #1 17885422
    pancyk
    Rate: 13
    Has anyone dealt with the issue of the flashing red light in the Dyson V6?
    After connecting the charger (26.1V 1A), the red light flashes and the battery does not charge.
    Having nothing to lose, I took it apart and took a few measurements:
    Each of the 6 cells has 4.6V - when measuring the entire bank it is 27.7V and the output from the electronics is 21.4V
    Do these parameters mean that there are insufficient cell resources, or do they have a charging counter in the system so that it simply stops working?
    The green LED lights up for a second after pressing the switch about 100 times
    Dyson V6 - Flashing red light while charging, cell measurements > Dyson V6 - Flashing red light while charging, cell measurements
  • #2 17885459
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    If the charger gives a lower voltage than the battery, how can it charge it?
    What kind of cells are these? If Li-ion, they are overcharged.
  • #3 17885489
    pancyk
    Rate: 13
    Nominally, the battery is supposed to output 21.6V, this morning, after disassembling it, I connected an external 28V charger directly to the terminal + and -, hence a slightly higher voltage than from the company charger directly on the bank, after this procedure, the output of the system is 21.5V and the lamp red still flashing.
    What I mean is whether it`s the fault of the batteries or the electronics - I was thinking about buying new cells, but if the problem is in the board, my actions will turn out to be in vain.
    these are Li-Ion cells
  • #4 17885507
    Level 37  
    Help: 211
    Rate: 1014
    Try to discharge these cells (each one separately) to 3.6V.
    Then check if they are charged with the original charger.
  • #5 17885720
    pancyk
    Rate: 13
    I discharged each cell to 3.6V and it`s still the same - the diode flashes red both when connecting the charger and after pressing the trigger, at the output from the board there is about 18V, which is a significant drop to the nominal 21.6V.
    I discharged it with a car vacuum cleaner and I feel that the batteries have a good capacity - I also connected a portable 12V compressor and it seemed to work.
  • #6 17886196
    brzeszczejaro
    I have the same problem, does anyone know what`s causing it?
  • #7 17886932
    Level 37  
    Help: 211
    Rate: 1014
    So the problem is probably in the electronics, not in the cells.
  • #8 17887244
    pancyk
    Rate: 13
    Today I connected a charger with a meter to the charging port and it seems that the electronics does not pass any current to recharge the batteries, nor does it send anything to the engine even after I charged the batteries, apart from the electronics.
    I`m trying hard to find a magic "reset" button, but I feel like it won`t work and maybe I`ll turn the set of cells into a nice, capacious power bank. :)
    Let`s leave the topic open, maybe someone will come up with something.
  • #9 17888596
    krankor
    I have a battery that behaves in the same way. The cells seem to be functional, voltages range from 3.6 to 4 V. I am thinking about downloading a replacement board from ebay or bang. Has anyone used such electronic boards before?
  • #10 19833165
    benek31
    On Aliexpress you can buy controller boards for DYSON faucets for both V6 and V8, of course, replacements and you need to pay attention to whether they have a balancer system, because they are also available without a balancer... and are available either with or without a switch.
  • #11 19833200
    W.Wojtek
    Phones specialist
    Help: 245
    Rate: 430
    The basic condition is that the charger must be original. If this is not the case, nothing will help, even with setting the voltage to 3 decimal places.
    If it is original, just buy the electronics from a Chinese company.
    That`s how Dyson figured it out. And as far as I know, no one has dealt with it. I had to buy three of these tiles...
The discussion revolves around the issue of a flashing red light on the Dyson V6 vacuum while charging, indicating a potential battery or electronics failure. Users report that the battery cells measure around 4.6V each, with a total voltage of 27.7V, but the output from the electronics is significantly lower at 21.4V. Suggestions include discharging the cells to 3.6V and checking the original charger, as well as considering the possibility of a faulty electronic board rather than the cells themselves. Some participants mention the availability of replacement controller boards on platforms like eBay and Aliexpress, emphasizing the importance of using original chargers and ensuring the new boards have a balancer system.
