Bosch AL 1115 CV - Damaged charger - lights up but does not charge
Beeo 14943 2
  • #1 16865056
    Beeo
    He greets everyone warmly and thank you in advance for your time.
    I suspect that the AL 1115 CV 3.6V-10.8V - 1.5A charger for the PSR 10.8 LI-2 screwdriver is not working properly.
    After inserting a discharged battery (with a voltage of approx. 8.75 VDC), the green LED blinks for a while (which in this model means charging) and then stops (which symbolizes charging).
    Unfortunately, the battery still has a voltage of 8.75 VDC and when inserted into the screwdriver, the generated power is so small that it can barely start and spin for a few seconds.
    I thought it was the "dead battery" fault, but I bought a new battery and it worked very well...until the first charge.
    Has anyone encountered a similar problem and know where to look for the cause?
  • #2 16866942
    Kamilpl123
    Help: 17
    Rate: 42
    I would start by analyzing the schematic, looking for any burnt elements on the board. Scheme below:
  • #3 16871811
    Beeo
    However, I decided to buy a new charger, as the cost was acceptable (PLN 69).
    Ultimately, I could spend a few hours trying to analyze and try without effect, and I would still have to buy a charger.
    I was hoping someone on the forum might have had a similar experience.
    For posterity:
    In my case, the new charger passed the exam. The screwdriver works like new.
    I'm closing the topic.
