Lenovo 700 15isk Laptop: Best M2 SSD Drive Options for PCIe Slot (Up to 256GB) & Compatibility
JaroFon 7545 8
  • #1 17280261
    JaroFon
    Help: 11
    Rate: 355
    Hello. I just got a pretty cool unit which is the Lenovo 700 15isk laptop. I expanded the RAM to 16 Gb in it. The laptop will serve me for a long time (I am not going to replace it for the next period of time), so I want to invest in an M2 SSD drive for it. At the moment, I have a SATA GoodRam Iridium PRO 240 Gb SSD installed. From the specification of this laptop I read (and I saw a PCIe slot inside) that you can install such a disk up to 256 Gb PCIe, from what I understand these are M2 disks. And here's my question, because I haven't read a more detailed specification of this PCIe slot anywhere. What is the best M2 drive I can install in this unit? As you know, M2 disks are available in a variety of prices and with various parameters, so I ask what the best disk (fastest) I can install here
  • #2 17280366
  • #3 17280374
    JaroFon
    Help: 11
    Rate: 355
    Samsung M2 disks from the 960 EVO Series, not to mention PRO, have very high sending and receiving speeds (the price is also high, but as I mentioned, I want to invest in the best disk possible), and therefore I ask if the PCIe slot in my equipment is fully will handle the capabilities of such a disk?
  • #4 17280516
  • #5 17280529
    JaroFon
    Help: 11
    Rate: 355
    Then, since the connector provides the full, highest transfer rate, what would you recommend for my equipment, of course up to 256 Gb?
    Jarzabek666 wrote:
    ... Samsung PM951 MZVLV256HCHP
    ... the aforementioned disk does not knock you down with its parameters, especially its write speed
    Added after 12 [minutes]:
    ... maybe such a disk Samsung 970 Evo M.2 250GB ?
  • #6 17280565
  • #7 17280607
    JaroFon
    Help: 11
    Rate: 355
    OK I understand. So if I mount, for example, this Samsung 970 Evo M.2 250GB drive, the socket in my laptop will fully support this drive. Another question that arises is is the PCIe slot in my laptop bootable or is it just a laptop memory expansion application? Let it not turn out that I will not boot the system on this socket
  • #8 17736214
    om1
    I am also faced with this problem: what disk to choose and whether it is possible to put a system on the m2 connector?
  • #9 18429177
    Nyuupl
    You can easily boot from m.2
The discussion centers around upgrading the Lenovo 700 15isk laptop with an M.2 SSD drive, specifically focusing on options for a PCIe slot that supports drives up to 256GB. Users recommend the Samsung 970 Evo M.2 250GB as a high-performance option, noting that the laptop's PCIe slot is PCI3.0 x4, allowing for maximum transfer speeds. Concerns about whether the PCIe slot is bootable are addressed, confirming that it is possible to boot from an M.2 drive. The conversation highlights the importance of ensuring compatibility and performance when selecting an SSD for this laptop model.
