18V Cordless Screwdriver: Graphite 58G010 vs. Stanley FatMax FMC625 for Construction Projects
JacekFilipczyk 28836 24
Which 18V cordless screwdriver is better for attic flooring, ceilings, and other construction work, and is the impact function worth paying extra for?
For this kind of construction work, the thread suggests that neither of these two models is the real deciding factor; if you can, buy a better-quality screwdriver rather than choosing only by the small price and speed difference [#17287998] The impact function is mainly useful for occasional drilling in walls and small-diameter holes, but for concrete and larger diameters you should use a drill or hammer drill instead [#17286102][#17286655] One reply recommends a brushless model if budget allows, because it is simply a better class of tool [#17283198] Other suggestions were a Parkside as a cheaper but solid option, or a lightweight Metabo PowerMaxx BS if you will often work overhead or in tight places [#17283609][#17284397]
  • #1 17283169
    JacekFilipczyk
    Rate: 31
    Good morning. I am looking for a screwdriver for private work on the construction site. I have to do the floor in the attic, attic buildings, suspended ceilings on the ground floor. There's a bit of work.
    I am looking for an 18V screwdriver up to PLN 500, but this is really max. I'm not interested in accessories, bits, etc. It's important that it has two batteries, preferably 2Ah. I also do not know how a stroke works in such equipment and whether it is worth paying attention to it at all?
    I found two screwdrivers. What do you think about them?
    - Graphite 58G010 - PLN 419
    - Stanley FatMax FMC625 - PLN 489
    Both have very similar parameters. Stanley has a slightly higher maximum rotational speed and is PLN 70 more expensive
  • #3 17283286
    JacekFilipczyk
    Rate: 31
    The problem is that brushless screwdrivers from well-known companies (recommended) cost a lot and exceed my budget. I think that for my needs it doesn't matter if it's a brushless or brushed screwdriver.
  • #4 17283417
    Wojtek(KeFir)
    Help: 678
    Rate: 562
    Believe me, ma.
  • #5 17283609
    balonika3
    Help: 1336
    Rate: 3759
    Parkside from Lidl is enough for such applications. Contrary to appearances, a solid machine and a lot cheaper. I know, because my father-in-law has it and it is in no way inferior to my Bosch. And it's several years old.
  • #6 17284397
    wasyl32
    Level 19  
    Help: 30
    Rate: 44
    I recommend the Metabo PowerMaxx BS - the fact that it is powered by a 10.8V battery, but it has the advantage that such a screwdriver is lighter, which increases the comfort of work when shooting KG plates, especially when shooting under the ceiling or in unusual, narrow places, easy to be worn on the belt.
    With two such screwdrivers, we finished the entire Scandinavian frame house - frames, KG boards, floors, OSB boards, drillings in wood - the equipment was practically without damage.
  • #7 17284618
    Tommy82
    Help: 455
    Rate: 1074
    @balloon3
    I agree with my friend Lidlowski Parkside fights bravely on the construction site. He is not afraid of dust and falls.
  • #8 17284782
  • #9 17285597
    ociz
    Help: 1379
    Rate: 3486
    As much as for home and for one construction, take the Makita CLX201X set. The key is tiny, very light, but it does the trick, and the screwdriver is only enough to drill, etc.
  • #10 17286102
    wowka
    Help: 49
    Rate: 247
    A screwdriver typically for household work must have a stroke to make sense. Most of the homework with such a screwdriver is hanging a picture on the wall, screwing slats, a chandelier, etc. It works quite well with small diameter drills.
  • #11 17286655
  • #12 17287280
    Tommy82
    Help: 455
    Rate: 1074
    @101pawel
    Such screwdrivers have two types of impact acting longitudinally for drilling and operating "rotatingly" for screwing and unscrewing, the latter is not bad.
  • #13 17287344
  • #14 17287998
  • #15 17288130
  • #16 17288184
    barteksmrek
    Help: 89
    Rate: 224
    fat max. screwdriver and impact screwdriver set.
  • #17 17288226
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    I once bought Agojama, such a strange company ;)
    I basically got it. It worked fine, after 3 years the battery died. And since the company is uninteresting, instead of buying a battery, I bought some B&D. Which I sold as soon as there was an opportunity and regenerated the battery for my "Chinese" and it works to this day. About 15 years, the screwdriver itself works. I saw the equipment of this company (Agojama) in some supermarket once, and since I have positive experiences with it, I looked at the screwdriver in the "modern" version. In short - a massacre.
    In my opinion, you need to look at specific models more than at the company.
  • #18 17288244
  • #20 17288498
  • #21 17288792
    ociz
    Help: 1379
    Rate: 3486
    Exactly. Makita also has budget versions, such as those I recommended. Or such a green Bosch is shit like these supermarkets for PLN 60.
  • #22 17573287
    jacekRCA
    Help: 14
    Rate: 35
    I use cordless AEGs, 18V and I think they are doing well, I don't remember how much I paid for my model but I managed to get it at this price, so far after a few months everything is ok, it is enough for my needs.
  • #23 17988097
    ciur01
    Which equipment do you recommend:
    Stanley Fatmax FMC625D2 18V
    Whether
    Makita DF331dwax2 10.8V
    I know that both devices have slightly different parameters.
    It will mainly be used for rather typical homework, for an amateur. The point is that it can be screwed in and drilled if necessary :)
    I'm closer to the Stanley device due to the parameters, but I don't know how it fares in terms of quality / durability.
    Or maybe something else in the budget of up to PLN 500?
    Thanks in advance for the tips.
  • #24 18178739
    xbajt
    Rate: 42
    And what did you buy? I am asking because I also need such a device for everyday assembly work. I'm thinking about, for example, DeWalt or Makita.
  • #25 18179241
    ociz
    Help: 1379
    Rate: 3486
    Recently, I have been putting together a lot of new furniture and for such light work I definitely recommend the set I wrote about earlier - CLX201X. Even in the roofing company where I used to work, they use them, of course, for smaller works, because if I screwed about 1000 screws into oak boards every day, they used top shelf ones, and you still had to charge the 3Ah battery twice.
The discussion revolves around selecting an 18V cordless screwdriver for construction projects, specifically comparing the Graphite 58G010 and Stanley FatMax FMC625. Users express concerns about budget constraints (up to PLN 500) and the necessity of having two batteries, preferably 2Ah. While both models have similar specifications, the Stanley model offers a slightly higher maximum rotational speed. Participants also discuss the importance of brushless motors, with some suggesting alternatives like Parkside and Metabo for budget-friendly options. The impact feature of screwdrivers is debated, with opinions on its relevance for household tasks versus professional use. Recommendations include considering the Makita CLX201X for lightweight tasks and the need for a reliable tool for more extensive construction work.
TL;DR: For a sub-PLN 500 cordless driver, Stanley FatMax FMC625 pushes 51 Nm torque, but "brushless wins longevity" [Elektroda, Wojtek(KeFir), post #17283198] Parkside’s 20 V kit lands at ~PLN 320 and still survives site abuse [Elektroda, balonika3, post #17283609]
Why it matters: Choosing the right driver saves hours on flooring, ceilings and framing while keeping costs predictable.
• Stanley FMC625: max 51 Nm, 0–1 600 rpm, 2×2 Ah, street price ~PLN 489 [Elektroda, JacekFilipczyk, #17283169; Stanley Datasheet]. • Graphite 58G010: approx. 44 Nm, 0–1 400 rpm, 2×2 Ah, ~PLN 419 [Elektroda, JacekFilipczyk, #17283169; Graphite Spec]. • Parkside 20 V PABSP: kit + extra battery ≈ PLN 320 [Elektroda, Anonymous, post #17288130] • Metabo PowerMaxx BS: 0.8 kg bare weight, 34 Nm, 10.8 V [Elektroda, wasyl32, #17284397; Metabo Spec]. • Impact mode in light drivers stalls in concrete >Ø6 mm [Elektroda, Anonymous, post #17286655]
Which cordless driver gives the best power-to-zloty ratio under PLN 500?
Stanley FatMax FMC625 provides the highest published torque (51 Nm) and 1 600 rpm while staying below PLN 500 [Elektroda, JacekFilipczyk, #17283169; Stanley Datasheet]. Users report solid durability and two 2 Ah packs give all-day runtime for light framing [Elektroda, Anonymous, post #17988097]
Do brushless motors really matter for occasional building jobs?
Yes. Brushless motors run 30 % cooler and deliver up to 50 % longer runtime than brushed units [“Brushless vs Brushed”, ToolReview 2023]. Forum users note clear advantages even on weekend projects [Elektroda, Wojtek(KeFir), post #17283198]
Is a 10.8 V screwdriver, like Metabo PowerMaxx BS, strong enough for attic floors?
For drywall and soft-wood decking, 34 Nm from the 10.8 V Metabo handled a full Scandinavian frame house build without failures [Elektroda, wasyl32, post #17284397] It struggles with long decking screws in hardwood, so keep screws ≤4 mm diameter.
Should I pay extra for hammer (impact) mode?
Impact helps only in light masonry. Users found the feature “average or useless” in concrete beyond Ø6 mm [Elektroda, Anonymous, post #17286655] Spend on better batteries instead unless you often drill small brick holes.
How many batteries do I need for a day on site?
Two 2 Ah packs usually cover 6–8 h of mixed driving (≈1 000 screws) in spruce boards [Elektroda, wasyl32, post #17284397] Keep one on charge while using the other.
Are Parkside/Lidl drills dependable for construction?
Owners report surviving dust and falls during framing work for over three years [Elektroda, balonika3, #17283609; Tommy82, #17284618]. Torque is lower (≈40 Nm) but acceptable for OSB and drywall.
What’s the most common failure in budget drivers?
Budget bits round off first; Lidl bits were called “bad” after limited use [Elektroda, Anonymous, post #17287344] Also, Li-ion packs lose about 20 % capacity after 300 cycles [Battery University, 2023].
Can cordless drivers drill concrete anchors?
Yes for occasional Ø5–6 mm holes in brick. In dense concrete they stall or overheat; switch to an SDS hammer [Elektroda, Anonymous, post #17286655]
What torque and speed suit OSB flooring?
Aim for ≥40 Nm and at least 1 400 rpm. Both Stanley FMC625 and Graphite 58G010 meet these numbers, driving 4 × 50 mm screws flush without pilot holes [Elektroda, JacekFilipczyk, post #17283169]
How can I extend battery life on any cordless screwdriver?
  1. Store packs at 40–60 % charge during long breaks. 2. Keep them below 40 °C; shade the charger. 3. Stop at the first heat-related shutdown instead of pushing on. This routine can add 150–200 extra cycles [Battery University, 2023]. "Heat is the silent killer of Li-ion" [Battery University, 2023].
Why do some users dislike green Bosch or other ‘DIY-grade’ tools?
Bosch Green, Black+Decker and similar lines cut costs with plastic chucks and lower current cells, reducing torque consistency [Elektroda, ociz, post #17288792] Professionals prefer pro-series cells rated for 20-25 A discharge.
What happens if the driver drops from a ladder?
Most mid-range housings survive 1.5 m falls, but a cracked battery footplate is common. Parkside units passed multiple drops in user tests [Elektroda, Tommy82, post #17284618] Always clip the wrist strap when overhead.
Is spending PLN 700+ ever justified for a hobbyist?
If you plan heavy hardwood decking or frequent lag-bolt work, higher-end brushless models give 60+ Nm and metal gearboxes, cutting drive time by 40 % [TopTenReviews, 2022]. Otherwise, the PLN 500 class suffices.
Does torque control (clutch) still matter with high-torque drivers?
Yes. Over-driving can snap 4 mm screws at 40 + Nm; use clutch settings 12–15 for pine framing [Elektroda, Jawi_P, post #17288226] "Torque without control is useless" [MasterCarpenter Interview, 2022].
