[Solved] 2007 Skoda Superb I: How to Unlock Door from Inside after Remote Locking? Tips Needed
Ka_Krzycho 18939 16
How can I unlock a 2007 Skoda Superb I from the inside after it has been locked with the remote control, and can this blocking function be disabled?
After remote locking, the car’s safe/super-lock function blocks the inside handles, so you normally cannot open the door from inside [#17285083][#17285572][#17287470] To disable it for that locking cycle, press the remote lock button twice within 2 seconds; then the car can be opened from the inside, but not from the outside [#17286945][#17287932][#17288860] This deactivation is only temporary and resets the next time the car is locked with the remote [#17288860] Some replies say permanent deactivation would require dealer/service software, and may not be available as a normal user setting [#17288190][#17288868][#17427380] If the function is active, the car may also show a “SAFE!” message in the center display [#17287470]
  • #1 17285056
    Ka_Krzycho
    I have been the owner of a 2007 Skoda SuperbI for half a year and by accident I noticed that after locking the door with the remote control I cannot open the car from the inside. I tried to pull the handle twice quickly from the inside, I was looking for a lock, a switch and nothing. I have been looking for three days on the Internet on various forums, I also did not find anything, I read the manual and nothing.
    For this, I am asking my colleagues for help, maybe someone knows how to open the door from the inside in my car, I am afraid that if I lock someone inside, he will not be able to get out of the car.
    If I can't get the information here, the skoda service will remain. Thank you in advance for all advice.
  • #2 17285083
    kortyleski
    Help: 957
    Rate: 3840
    The so-called super lock is supposed to work.
  • #3 17285130
    Ka_Krzycho
    And you can not get out of the car in any way if someone closes the remote control? Can you turn it off somehow?
  • #4 17285523
    Ireneo
    Help: 746
    Rate: 2457
    In principle, there should not be a situation where someone sits inside and another closes with the remote control.
  • #5 17285572
    helmud7543
    Help: 1216
    Rate: 1563
    Can not. If you cannot open the driver's door mechanically with the key, you only need to be careful. This is not the only car with such a function.
  • #6 17285974
    robin161
    Help: 74
    Rate: 273
    Super-Lock is one of the anti-theft security measures. I do not know about Skoda, but many such functions can be turned off / on from the website. Ask at the Dealership.
  • #7 17286051
    andrzej20001
    Help: 1573
    Rate: 6628
    In newer models, e.g. the Touran, from 2010 it helps to press the remote control again. There is even info on the display
  • #8 17286457
    Ka_Krzycho
    The point is that you accidentally lock someone in the car, and this has happened once and that someone will not get out in any way until I open the door with the remote control. Well, I only have an ASO if I find out how to disable this blockade, I will write here soon, thank you all.
  • #10 17286827
    Strumien swiadomosci swia
    Help: 1403
    Rate: 6390
    It is worse when the zipper breaks in the locked position, you have to tear the cover and the zipper, and this is quite a frequent service for me.
  • #11 17286945
    SKM 1964
    Help: 150
    Rate: 660
    For me, it is possible to turn off the bolts, you have to turn the key within two seconds, so that the LED from the central lock does not flicker and after a shout. You will come out from the inside, you will not enter from the outside. :|
  • #12 17287470
    Ka_Krzycho
    I already know something, my spouse found on the forum:
    http://forum.octaviaclub.pl/forum/octavia-iii...elektryka-i-elektronika-ab/49709-funkcja-safe
    One gentleman wrote there
    Safelock function
    The central locking locks are equipped with a lock. Door locking from
    outside, the locks are automatically blocked. Indicator light w
    the driver's door flashes quickly for 2 seconds, then slower in even mode
    intervals. The door cannot be opened either by the inside or outside handle.
    This solution makes it difficult to break into the car.
    The lock can be disabled by locking twice within 2 seconds
    If the Safelock function is activated after locking the car, the
    In the center display the message Attention SAFE! User manual!
    Tomorrow I will check it and write if it worked.
  • #13 17287932
    SKM 1964
    Help: 150
    Rate: 660
    So it will be similar to me, as I wrote, But it has to be done within two seconds.
  • #14 17288190
    robin161
    Help: 74
    Rate: 273
    The described method is an ad hoc method. However, there are methods - I don't know about Skoda - to deactivate / activate the function permanently, carried out by the service software - at the user's request.
  • #15 17288860
    Ka_Krzycho
    As I wrote, double pressing the remote control to close deactivates the lock, but only until the next closing of the car with the remote control. I don't know how to permanently disable this feature. I'm going to go to an ASO, I'll write something if I find out.
  • #16 17288868
    Ireneo
    Help: 746
    Rate: 2457
    Rather, there will be no such option.
  • #17 17427380
    Ka_Krzycho
    Unfortunately, these types have that, it is not possible to disable this function without interfering with the software. I finish this topic, thank you all for your willingness to help.
✨ The discussion revolves around the inability to unlock the doors from inside a 2007 Skoda Superb I after the vehicle has been locked using the remote control. This feature, known as the "Super-Lock" or "Safelock," is an anti-theft mechanism that prevents doors from being opened from both inside and outside once locked. Users confirm that this function is designed to enhance security, making it difficult for someone inside the car to exit if the doors are locked externally. Some participants suggest that the function can be temporarily disabled by double-pressing the remote control within two seconds, but it reactivates upon the next locking. Permanent deactivation may require service intervention. The discussion highlights concerns about safety if someone is accidentally locked inside the vehicle.
TL;DR: On a 2007 Skoda Superb I, SafeLock has a 2‑second window; "Door cannot be opened either by the inside or outside handle." Double‑press lock within 2 seconds to let passengers exit, or unlock from outside. [Elektroda, Ka_Krzycho, post #17287470]
Why it matters: For Skoda Superb I owners who want to avoid trapping occupants and need clear steps to manage SafeLock behavior.
What is SafeLock (super lock) on a 2007 Skoda Superb I?
SafeLock is the deadlocking feature. When you lock from outside, it blocks both interior and exterior door handles. The driver-door LED flashes quickly for about 2 seconds, then slower. A cluster message like “Attention SAFE! User manual!” can indicate activation. It is a theft‑deterrent mode that prevents opening from inside after locking. Disable it before leaving someone inside. [Elektroda, Ka_Krzycho, post #17287470]
Can I open the door from inside after remote locking?
No, not when SafeLock is active. It disables interior and exterior handles. You must unlock from outside with the remote or key. To avoid trapping someone, disable SafeLock before locking by double‑pressing the lock button within two seconds. Use the LED pattern to confirm status. [Elektroda, Ka_Krzycho, post #17287470]
How do I temporarily disable SafeLock so passengers can exit?
Use this quick procedure before someone remains inside:
  1. Close all doors.
  2. Press the remote’s lock button twice within 2 seconds.
  3. Verify by testing an interior handle from inside. This disables SafeLock for that lock cycle only. Locking the car again will re‑enable SafeLock unless you repeat the steps. [Elektroda, Ka_Krzycho, post #17287470]
How do I lock the car but still let people exit using the key?
Use the mechanical key in the driver’s door. Turn the key within two seconds so the central‑lock LED doesn’t start flashing. This disables the deadlock bolts for that cycle. People can exit from inside, but entry from outside remains blocked. Timing is critical for this to work. [Elektroda, SKM 1964, post #17286945]
Can a dealership permanently disable SafeLock on a Superb I?
According to owner feedback, no simple dealer setting exists. Permanent deactivation would require software modification. The thread author closed the issue noting it isn’t possible without interfering with software. Ask your dealer for confirmation, but plan on it staying enabled. [Elektroda, Ka_Krzycho, post #17427380]
Why does my display show “Attention SAFE! User manual!” after locking?
That message signals SafeLock is active after you lock the car. When armed, the driver-door LED flashes quickly for about 2 seconds, then slowly. In this state, interior and exterior handles will not open the doors. Disable SafeLock before locking if someone must remain inside. [Elektroda, Ka_Krzycho, post #17287470]
Does pressing the remote again change locking on newer VAG cars?
Yes. On a 2010 Volkswagen Touran, pressing the remote again influences locking and the display shows guidance. This highlights VAG differences by model and year. Your Superb I lacks such prompts, so rely on the double‑press disable method described above. [Elektroda, andrzej20001, post #17286051]
What does the LED flash pattern on the driver’s door mean?
Fast flashing for about 2 seconds after locking indicates SafeLock is arming. It then switches to slower, even flashes while armed. Use this pattern to verify status before leaving a passenger inside. If you disable SafeLock during locking, expect different feedback or no SAFE message. [Elektroda, Ka_Krzycho, post #17287470]
What if the lock jams while deadlocked?
A seized latch in the locked position can require destructive access. Technicians report removing the door trim and breaking the latch to open. It’s described as a fairly frequent workshop task. Address sticking locks early to avoid escalation under deadlock. [Elektroda, Strumien swiadomosci swia, post #17286827]
Someone is locked inside my Superb—what should I do?
Unlock the vehicle from outside with the remote or the mechanical key. Interior handles will not release while SafeLock is active. Ensure your key cylinder works to guarantee access. Avoid arming SafeLock when someone stays inside the vehicle. [Elektroda, helmud7543, post #17285572]
Is SafeLock really for theft protection?
Yes—“Super-Lock is one of the anti-theft security measures.” It prevents thieves from using interior handles after forcing entry. That design explains why passengers cannot open doors from inside when it’s armed. Use the temporary disable method when needed. [Elektroda, robin161, post #17285974]
Pulling the inside handle twice didn’t open the door—why?
Double‑pull behavior does not override SafeLock on the Superb I. The system blocks interior handles entirely when armed. That’s why two quick pulls from inside did nothing after remote locking. Disable SafeLock before locking if someone must exit later. [Elektroda, Ka_Krzycho, post #17285056]
