Configuring GT02a GPS Tracker from AliExpress for use with GPS-Trace
G.R77 26178 48
How do I configure a GT02A GPS tracker to work with GPS-Trace?
Set the GT02A to GPRS, configure the APN, then point it to the GPS-Trace server and add it as a TK110 device with the correct ID [#17289065] [#17852066] Send `APN, 666666, internet, internet, internet #` for Orange-style settings, or `APN, 666666, internet #` for Play, and make sure the tracker replies `OK` [#18358823] [#18119157] [#19056937] Then send `SERVER, 666666,0,193.193.165.37,32329,0 #` for the newer GPS-Trace/Ruhavik setup, or older GPS-Trace instructions that used `193.193.165.166/167` with port `20488/20448` [#18155056] [#17852066] In the web app, choose device type `TK110` / `Resiont TK110` and enter the tracker’s ID; newer versions use the full 15-digit IMEI, while older setups used the Wialon-derived Unique ID from `id.wialon.net` [#17852066] [#18358823] [#18155056] If it still does not send data, do a factory reset first with `FACTORY, 666666 #` and then resend APN and SERVER [#18155056]
  • #1 17286585
    G.R77
    Good morning
    I bought a gps tracker on ali: GT02a
    I put the orange card ... after sending the text, he gives the position, but I don't know how to run it on "gps-trace"
    I am asking you for help, thank you in advance. Pzdr GR
    bsp5020
    Help: 17
    Rate: 76
    What stage are you at? According to the CONCOX Orange GPS Trace documentation is listening on port 20351. Were you able to switch the SMS mode to GPRS?
  • #3 17289722
    G.R77
    Thanks for showing interest
    I installed the dyegoo apke on the phone and it works as it should, so the topic is overwhelmed
    I couldn't use gps-trace :(
  • #5 17445982
    Pablo122_2008
    Hello, please help me login to gps trace.
    GPS responds to text messages but nothing else ... The device is a dyegoo GT02A
    best regards
  • #7 17492455
    sikor22000
    G.R77 wrote:
    Good morning
    I still can not set it, the GPS trace does not work all the time, the sms gives the best locations
  • #8 17819916
    procesor0
    Settings for the Gt02A tracker on the website orange.gps-trace.com command: server, 666666,0,193.193.165.167,20488,0 #
    When you find your tracker at id.wialon.net, change the ip to 193.193.165.166
  • #9 17851994
    Piotr2704
    Hello and I need someone to help me with gt02a. I would like it to work on the Orange gps-trace website. Now the details of the SMS commands are running flawlessly on google maps. I logged in to the GPS trace and I do not know how to configure it to flicker. The card is from the English O2 network because I live in the UK. I did not introduce any APN commands for fear that it would stop working at all. Could someone explain it to me somehow in simple language. Thanks in advance
  • #10 17852066
    bsp5020
    Help: 17
    Rate: 76
    You must obligatory set APN to be able to send anything via GPRS. GoogleMaps after SMS will not disappear, no worries.
    I assume you haven't changed your password and it's still 666666:
    APN, 666666, mobile.o2.co.uk, o2web, password #
    SERVER, 666666.0,193.193.165.167.20488.0 #
    You go to id.wialon.net and look for your ID from the sticker from the device. As you can see them at port 20448 is half the battle.
    At http://orange.gps-trace.com/ you create a profile. In Profile as device you set "Device type" as TK110 and there you paste the full ID into the "Unique ID" field that you had on id.wialon.net. If there was zero in front, it was zero.
    Another sms to the target server:
    SERVER, 666666.0,193.193.165.166.20488.0 #
    Log out, log in and it should work.
  • #11 17854174
    Piotr2704
    I have run out of private messages to bsp5020, buddy, can you give me your phone number in a private message to complete our conversation
  • #12 17891500
    Denio001
    Rate: 11
    Hello? I will connect to the topic. I bought a gps gt02a with a play card, top-up and an internet package. I am asking for step by step help on how to get it started because I don't know much about it and I don't understand anything from previous posts.
  • #13 17965350
    Czlowiek87
    Hello, on the right I join the TK110 without any problems, does anyone have an idea how to attach another one on the left, on what port and under what name of the device?
    Thank you very much in advance.
  • #14 18112768
    krzysiek478
    Hello, does anyone know how to change the imei number ?? something changed and when I check the imei number it crashes me 88888888888, of course, the tracking does not go.
    best regards
  • #15 18113189
    bsp5020
    Help: 17
    Rate: 76
    You have information about an incorrect IMEI number from SMS, is it visible on id.wialon.net? If you want to check what the tracker is sending in a frame via GPRS, write to PW
    Moderated By nutergsm:
    We help on the forum, not at PW
  • #16 18113229
    krzysiek478
    Hmmm, he receives the ID number from a text message. Honestly, I have never used wialona and I don't know how to go about it
  • #17 18113243
    bsp5020
    Help: 17
    Rate: 76
    Have you tried factory settings (as I guess you have GT02A after the topic)? When you send a text message saying "SERVER, 666666,0,193.193.165.167,20448.0 #" here http://id.wialon.net/ at the port "20488" you will see your IMEI (fragment) (ie theoretically wrong - 88888888888) but do a factory reset first.
  • #18 18118609
    Iwo-I3
    I bought a gps tracker on Ali: GT02a, I put the orange card, I can't set GPRS to ON for nothing. What should be the command to set the APN correctly in this tracker? thank you for your help !!!!
  • #20 18119685
    Iwo-I3
    Thank you for your help it helped !!!
    Added after 16 [minutes]:
    Hello !!!
    I am asking for help, I bought a car from Sweden. When connecting the camera to the installation, I found a GPS-GSM locator name NX50 gps: NEO-6,
    GSM IMEI .......
    Has anyone seen such a device, can it be used in our conditions, will it run on our SIM card, what commands to give. I will be grateful for the information. Regards !!!
    Hello !!!
    GSM IMEI .......
  • #21 18124933
    Czlowiek87
    I repeat the question: "Hello, I am joining the TK110 on the right side without any problems, does anyone have an idea how to attach another one on the left side, on what port and under what name of the device?
    Thank you very much in advance."
  • #22 18153241
    los_sombreros
    Help: 7
    Rate: 25
    Hello. I also have a problem with the GT02a configuration, the orange card.
    sms went like this:
    "APN, 666666, internet, internet, internet #"
    after each answer: OK
    On GPS TRACE (I see that some new version) I set the TK 110 device and according to what they require as the ID, I gave the full IMEI of the tracker, i.e. 15 digits, not like it was in the previous version that 11 last and 0 in front.
    After entering this data on GPS TRACE the following appears:
    Server IP Address: 193.193.165.37
    Port: 32329
    I also tried like this:
    SERVER, 666666,0,193,193.165.37.32329.0 #
    Did not help.
    On http://id.wialon.net/ after sending sms "SERVER, 666666,0,193.193.165.167,20448.0 #"
    displays at port 20488 Unique ID composed of the last 11 digits of my IMEI and 0 on the front.
    According to what was written in this topic, I should send back the sms: SERVER, 666666,0,193.193.165.166,20488,0 # and paste the Uniqe ID from wialon.net into the gps trace, but there is no such short, only full IMEI .
  • #23 18155056
    los_sombreros
    Help: 7
    Rate: 25
    finally succeeded with this new GPS trace.
    1.I did a factory reset - sms: FACTORY, 666666 #
    2. APN, 666666, internet, internet, internet #
    3. SERVER, 666666,0,193.193.165.37.32329.0 # -
    So it looks like the tracker with the new gps trace must be set for the server IP: 193.193.165.37 and Port: 32329
    the full 15-digit IMEI of the tracker must be entered as the ID.
    PS how much data do these devices consume on average per month?
  • #24 18234132
    morfeusz333
    800kB per day. Shipped every 30s.
  • #25 18317170
    scu84
    Hello, I have a similar problem, despite the SMS sent, the location on the Dyegoo application does not work, will someone help me configure ??
  • #26 18323925
    los_sombreros
    Help: 7
    Rate: 25
    Forget Dyegoo, you better try on Gps Trace.
    If gt02, I can tell you how to configure
  • #27 18355872
    SzwedzkiPedro
    if you can help me with gps trace
    I did this:
    sms
    factory, 666666 #
    opd:
    factory ok!
    sms:
    apn, 666666, internet, internet, internet #
    answer:
    apn ok!
    sms:
    SERVER, 666666.0,193.193.165.37.0, #
    Answer:
    SETUP IS OK! IP: 193.193.165.37 # 32329 #
    on GPS Trace after entering the data, i.e. full imei, unfortunately, does not work
    I don't really know what to enter in the DEVICE CATEGORY field :(
    if you can step by step ...
    thanks in advance
  • #28 18358823
    los_sombreros
    Help: 7
    Rate: 25
    enter the 15-digit device name on the GPS trace,
    select the device TK 110 (Resiont TK110) from the list. Configuration data will appear:
    Port: 32329
    Send these two texts to the number of the card used in the tracker:
    1. APN, 666666, internet, internet, internet # (where: Apn, password, apn name, apn user, apn password)
    2. SERVER, 666666,0,193.193.165.37.32329.0 #
    attention :
    APN, 666666, internet, internet, internet # - this is for e.g. Orange
    , apn name, apn user, apn password may be different in each network. For example, for Play it will be: APN, 666666, internet #
    because for this network apn user, apn password is left blank
  • #29 18359622
    SzwedzkiPedro
    go on meatball, I wonder if it's not because I have not checked if the sim card works in the smartphone?
    on comedy url ... etc replies: /
    do you still have any ideas?
  • #30 18359724
    los_sombreros
    Help: 7
    Rate: 25
    is the GT 02 tracker? After sending the above-mentioned texts to him, he confirmed "OK" after each? What network?
    What did you enter in the first SMS with the APN settings?
The discussion revolves around configuring the GT02A GPS tracker purchased from AliExpress for use with the GPS-Trace application. Users report challenges in setting up the device, particularly in switching from SMS mode to GPRS and entering the correct APN settings. Key steps include sending SMS commands to set the APN and server IP, with specific configurations for different mobile networks. Users also share their experiences with the Dyegoo app and GPS-Trace, highlighting the need for correct device identification and server settings. Successful configurations involve sending commands like "APN, 666666, internet, internet, internet #" and "SERVER, 666666,0,193.193.165.37,32329,0 #". The conversation emphasizes troubleshooting tips and the importance of using the correct IMEI and device type in the GPS-Trace application.
TL;DR: Average GT02A traffic is 0.8 MB/day when pinging every 30 s [Elektroda, morfeusz333, post #18234132] "Factory reset first" saves hours of debugging [Elektroda, los_sombreros, post #18155056] Configure APN, server 193.193.165.37, port 32329, device TK110, ID = 15-digit IMEI.
Why it matters: Correct first-time setup prevents silent data drain and lost location reports.
• Default SMS password: 666666 [Elektroda, bsp5020, post #17852066] • New GPS-Trace (Ruhavik) server: 193.193.165.37 : 32329 for TK110 [Elektroda, los_sombreros, post #18155056] • Free plan tracks up to 3 units [Elektroda, bsp5020, post #18370408] • Reset command: FACTORY,666666# [Elektroda, los_sombreros, post #18155056] • Data usage: ~0.8 MB/day ⇒ ~24 MB/month [Elektroda, morfeusz333, post #18234132]
How do I switch a GT02A from SMS to GPRS for GPS-Trace?
Send three texts in order:
  1. FACTORY,666666# (clears old settings).
  2. APN,,,,#.
  3. SERVER,666666,0,193.193.165.37,32329,0#.
    The tracker answers “OK” after each command and starts GPRS mode automatically; no separate GPRS command is needed on TK110 firmware [Elektroda, los_sombreros, post #18155056]
How much mobile data will a GT02A use per month?
At 30-second reporting it consumes about 0.8 MB/day, totalling roughly 24 MB/month [Elektroda, morfeusz333, post #18234132] Lower the TIMER value to 60 s to halve usage.
Can I track more than three devices on GPS-Trace?
The free tier limits you to three units [Elektroda, bsp5020, post #18370408] For four or more, upgrade to a paid Flespi or Ruhavik plan (from ≈ €3/month per additional unit, vendor pricing).
My tracker reports IMEI 88888888888. How do I fix it?
Corrupted IMEI points to bad settings. Send FACTORY,666666# followed by the APN and SERVER commands. Check id.wialon.net; a valid 15-digit IMEI should appear [Elektroda, bsp5020, post #18113243]
How can I add multiple GT02A units in one Ruhavik account?
Create one unit per tracker with device type “Resiont TK110,” unique 15-digit IMEI, and the same server:port for each. Free accounts show three units; excess devices stay offline until you upgrade or create another account [Elektroda, bsp5020, post #18370408]
Which SMS commands confirm the tracker is online?
  1. STATUS,666666# – replies with GPS and GPRS state [Elektroda, pawel55, post #18851934]
  2. TIMER,666666,30# – sets and confirms 30 s upload interval.
  3. CHECK,666666# – returns time, battery, and last fix (standard TK110 manual).
Dyegoo app shows only login—how do I access it?
Enter the sticker ID as username and password 123456. If login fails, the seller may have disabled that cloud; switch to GPS-Trace or Ruhavik for active support [Elektroda, bsp5020, post #19056951]
