TK905 GPS Transmitter Configuration: Play Card, Verykool Jet II SL5008, IP Address & Port
DexusMoll 11424 10
How do I configure a TK905 GPS tracker with a Play SIM card so it shows up online in mytkstar.net?
The thread does not give a specific IP address or port; the working setup mentioned is to set the APN to `internet`, enable GPRS forwarding, and power-cycle the tracker after sending the settings [#16712299][#18361744] One user reports that on Play the SMS command is `apn123456 internet`, and after removing and reinserting the SIM the tracker started working [#18361744] Another reply notes that some Play tariffs do not work with these trackers because they operate on 2G, while the SIM may be provisioned for 3G and above; `Play na Kartę renew` was reported as working [#18406511]
  • #1 16366480
    DexusMoll
    Hello, I bought the tk905 gps transmitter, I have a problem because I do not know how to configure it so that it shows the location of the device on the online website, the card that is in the device is the play card. Can someone tell me how to do it? When I log in on the play page, this device is called Verykool Jet II SL5008. I set the apn to the internet.
    After sending a text message for the GPS location, a text message with the location normally comes, but when I log on to the site that is provided for locating, mytkstar.net does not show the GPS there. '' TKS1-08965Logged Off ''
    What ip address and port should I set?
    I've already set it all up and it works.
  • #2 16372133
    jag888
    Rate: 11
    can you buddy share how? I have the same problem
  • #3 16712299
    kowal269
    Rate: 9
    Unfortunately, I did not use these GPS on Play. They certainly work on Orange and Virgin, maybe on other networks, but I haven't tested it. You just need to set apn. For Virgin and Orange it is "internet" and set up GPRS forwarding.
    Then turn off the device and turn it on after a while. It won't work right away - it's worth a drive and after a few minutes it will start dumps to the server. Next time it will drop as soon as it is turned on.
  • #4 18163391
    Kowal0104
    Hello, I have the same problem with the play card.
    I am asking for tips on what to do to make the tracking real. Best regards!!!
  • #5 18237076
    Ostryga70
    I have another problem. My locator works, but the refresh is set not less than 30 seconds, and I need to watch more often, even online. Is it possible to set a higher frequency?
  • #6 18237086
    bsp5020
    Help: 17
    Rate: 76
    As stated in this instruction (https://gts4b.com/file/796/TK905.pdf), you can configure it by sms: "upload123456 10", where "10" is the second interval between sent packets.
  • #7 18237217
    Ostryga70
    Thanks, it works. This is one more thing. How do I set an audible alarm to sound when an object leaves a Geo-fence?
  • #8 18326215
    lwisnia22
    It doesn't work for me either. I have already set various options and cannot catch range (all ranges - lte / 3g / 2g, 3g / 2g / and only 2g) Offline all the time. Also the orange card. What do you have to do?
  • #9 18361168
    AMRIF
    Rate: 11
    I have the same - saw the position once and sent it to the app and so it was now still offline. What port is setting? APN and then empty login and password?
  • #10 18361744
    lwisnia22
    I set it via SMS. In play apn123456 internet, in Orange apn123456 internet internet internet so far everything works. After this setting, I pulled out the card and when I put it back in, it started working.
    Additionally, earlier SMS admin123456 (phone number to which notifications are to be sent) without brackets
  • #11 18406511
    porto
    I know that in some PLAY cards for the Internet, trackers have a problem to work, I don't remember what tariff it was.
    If my memory is correct, it was because the trackers were working in the 2G network and the card was working on 3G upwards.
    In turn, I have absolutely no problem with the tariff: Play na Kartę renew.
    In my opinion, it is currently the most favorable.
    You buy a starter for PLN 5, top up for another PLN 6
    And then from the services you choose 50 sms to all networks for PLN 5 and 1 GB of the net also for another PLN 5.
    A zloty remains on the card and its validity is as long as the purchased packages do not end or the account runs out :-)
✨ The discussion revolves around configuring the TK905 GPS transmitter to display its location on the mytkstar.net website. Users report issues with the device not showing online despite receiving location texts. Key suggestions include ensuring the correct APN settings (e.g., "internet" for Play and Orange networks), performing a device restart after configuration, and using SMS commands to adjust settings such as the reporting interval. Some users mention that certain Play cards may not support 2G networks, which could affect functionality. The importance of using the correct IP address and port settings is also highlighted, with some users successfully resolving their issues by re-inserting the SIM card after configuration.
