Choosing the Best Van for DIY Motorhome Conversion: Factors to Consider
porywacz_zwlok 29868 18
Which used van should I buy to convert into a DIY camper, balancing reliability, low running costs, and enough ability to handle rough dirt roads?
The thread points first to a post-2002 Citroën Jumper / Peugeot Boxer / Fiat Ducato as the safest general choice for a camper base [#17289939] If you want specific versions, one recommendation was a Boxer L3H2 with the 2.8 HDi engine, while avoiding the 2.0 and 2.2 diesels; another suggested Vivaro L2H2 with the 2.0 CDI 114 hp, Ford Transit 2.0 TD 100 hp after 2002, or a Sprinter 212/312, with 313 CDI or 316 if you can find a good one [#17292043] For a more robust older option, the LT35 with the 2.5 TDI R5 was described as a durable engine choice, and Ducato/Boxer/Jumper were praised as solid and fairly good on rough roads [#17293233] A Trafic 2006 with the Nissan 2.0 dCi chain engine was also praised as a reliable high-mileage option, with the advice to buy a bus based on a good, proven engine and then adapt it to camper use [#17291890] One caution raised was to think about future diesel restrictions in Europe, since long-term travel may be affected by entry bans and Euro rules [#17292430]
  • Seeking reliable van platforms for DIY motorhome conversion
    #1 17289917
    porywacz_zwlok
    Rate: 21
    Hello, I'm not sure if I put a thread in the right place, but I need a little exposure to the matter in relation to the planned purchase of the car.
    Well, with my wife, we decided to buy a VAN for the tourist car. I will do all the work myself, and here I have browsed dozens of guides and I am full of knowledge about dozens of solutions, that is, I do not know anything at all. I have no problem with woodwork, simple mechanics or simple electrics. The car is supposed to be civil in appearance, but it should allow you to sleep comfortably for a few weeks inside, have a small kitchen and a small cabinet to carry a supply of onions and dumplings ;) .
    Going to the bottom. We must choose the basis of this whole story that will serve us for many years. We can not afford a new car and we do not want a used motorhome, because riding a motorhome to many countries is associated with restrictions and many costs, just because it is a motorhome. Are you able to indicate two solutions that will fluctuate between the ideal solution and the cheap solution? Why two? We have not yet set up a budget, although we have already set aside some money for this purpose, but we need help in choosing a solution that is closer to the cheaper option and a solution that is closer to the optimal one.
    The car is not meant to be a racer, because such travel is in itself a pleasure. What counts here is failure-free, be the failure that both European and Asian websites will be able to grasp. We drive with Toyota, so we never had the opportunity to use cheap parts, but a long time ago I had a punto and there the replacement of the entire braking system cost as much as replacing the yaris blocks. Cheap, but more often. We accept cheaply and more often, as well as expensive and rare. If our travels are not a race, we are counting on economical combustion at least in this matter, while treating the gas pedal calmly. The last important issue is off-road. It sounds scary, but the car must be able to navigate the forest tracks and slaughtered dirt roads. I am talking here about rolling through such an environment, but such routes are burdened with deep holes or ruts and it would be good if the car did not hang up at every possible opportunity.
    I hope that you will show us the right cars with the suggestion of the vintage and the model of the engine. Thank you in advance for your help and suggestions.
  • #2 17289939
    nici
    Help: 266
    Rate: 979
    Jumper / Boxer / Ducato after 2002 year.
  • #3 17289962
    andrzej20001
    Help: 1578
    Rate: 6669
    Buy a maxi ambulance.
  • #4 17290039
    nici
    Help: 266
    Rate: 979
    These cars are tortured friend ...
  • #5 17290288
    Romek T.
    Help: 7
    Rate: 43
    And what you mentioned above will be art nuns :D
    The bus class is always exhausted.
    I propose to adjust the Nissan or Toyota pick-up to the set requirements.
  • #6 17290294
    nici
    Help: 266
    Rate: 979
    Not every bus had to be plated on a construction site and the ambulance was practically all depleted to its limits before leaving the service.
  • #7 17290338
    dizba
    Help: 239
    Rate: 808
    How many people would be registered? What about the approval?
  • #8 17290355
    porywacz_zwlok
    Rate: 21
    for two or three, depending on how many seats there will be. and homologation for what?
  • #10 17290712
    porywacz_zwlok
    Rate: 21
    I do not intend to modify the cab and change trucks in a camper or in a universal one. I do not intend to use external electrical installations, so I do not have to apply for homologation.
  • #11 17291112
    Megawe
    Help: 246
    Rate: 1438
    The easiest way is to convert a food truck, one wall is opened, you can use it and make a sofa bed extra.
  • Jumper, Boxer, or Ducato after 2002 recommended
    #12 17291890
    adversus
    Level 32  
    Help: 188
    Rate: 597
    nici wrote:
    Jumper / Boxer / Ducato after 2002.
    I agree with a friend, and it does not mean that he must be tortured ...
    I bought Traffica 2006 with a documented history and a course of less than 160,000. km, where there is a 2.0 DCi nissan engine, with an inetrcooler and a turbo, with timing on the chain ... these engines lurk even 800,000. km. So look for buses with a good (reliable) engine and look at the possibility of adapting to a motorhome :)
  • Diesel engine and van model recommendations
    #13 17292043
    kakibara
    Help: 202
    Rate: 1284
    Boxer l3h2. Perfect would be l4. The engine only 2.8hdi. 2.0 and 2.2 do not even think.
    Vivaro l2h2. 2.0cdi 114KM. Or how you find the 2.0 gasoline super engine on such gas poetry trips while refueling.
    Diesel is already abroad and not only on the 1.52 Eura motorway, but more on the south.
    Transit 2.0 td 100KM after 2002 on a regular pump.
    The perfect sprinter would be 212 or 312 - but find a nice ...
    313 cdi or 316 long once up - on one wall you will earn a bunk bed and you will still squeeze under the bulkhead wall.
    Vivaro and jumpy l2h2 - maybe two people will be enough?
    Vivaro until 2009 is without a dpf filter. The dog is probably only 120HP - there is still 1.6 hdi but this can be compared probably to the old j5 in 2.5d - its performance.
  • Diesel access restrictions and gas tunnel issues
    #14 17292430
    Tommy82
    Help: 455
    Rate: 1074
    With a long service life, I would be afraid of restrictions in moving diesel.
    Entry bans etc without minimum Euro 5 or 6 minimum.
    With gas it can be a porb in some tunnels.
    Theoretically, it is probably better to have a bus in a car park, that you can carry less weight. And sometimes such buses bring people to work back and forth in a circle of up to 50 km a day.
    they can be stuck inside, but you'll probably screw it up anyway.
  • #15 17292644
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7832
    Or maybe an isothermal / refrigerated car? The possibilities of adaptation are huge, and quite simple enough. I even have a few friends who have put boxes out of the cold storage containers themselves. And besides, there is a lot of room for such things under such a building (additional / larger fuel tank, accumulators, drinking water tank / for hygienic purposes, waste tank etc.).
  • #16 17293233
    dodek10
    Rate: 68
    Search for the max bus - sprinter 316 or LT 35. Personally, I would choose LT with 2.5tdi r5 engine - armored motor, or some petrol with LPG though hard to find.
    The above they have some problems with sheets. what they do not have Boxery and Jumpery and dukato above by a colleague (only those have smaller shacks).
    However, dukato is also cool and solid + good for holes - many construction crews torture them off roads for construction.
  • #17 17295237
    porywacz_zwlok
    Rate: 21
    The list is already precise and I thank you very much for that. In another place where I asked, there appeared a Mercedes sprinter, which I have not seen here. For a moment I also thought about T4 or maybe give up the back and make the bed in the galaxy. I do not know. I have to decide something for spring, and that's not much time.
    Nevertheless, thank you for your help, I wrote down the cars and I will analyze every piece of equipment and every motor installed in them.
  • #18 17297401
    dodek10
    Rate: 68
    There are still cool versions of various cars in the Westfalia version on the market. The point is that there is a roof that you can lay down on a campsite and you can sleep there in a tent. They are, for example, Sharany or T4 or vito. But also for example Kia. At your place I would think about such sharanem / Alhambra or you will like camping themes at all. PS I forgot that these versions also have a mini sink built into the boot and sometimes also a mini gas cooker
  • #19 17297438
    Zbigniew 400
    Help: 283
    Rate: 794
    Did you not consider the motorhome to be renovated?
The discussion revolves around selecting the best van for a DIY motorhome conversion, emphasizing the need for a reliable and civil-looking vehicle that can accommodate sleeping and cooking facilities. Recommendations include models such as the Citroën Jumper, Peugeot Boxer, Fiat Ducato (post-2002), and Nissan or Toyota pickups. Users also suggest considering maxi ambulances and food trucks for their adaptability. Concerns about engine reliability, maintenance history, and potential restrictions on older diesel vehicles are highlighted. The importance of homologation and vehicle registration for modifications is also discussed, with suggestions for models like the Mercedes Sprinter and VW T4. The conversation concludes with a mention of Westfalia versions and other compact vehicles with built-in amenities.
TL;DR: Planning a DIY van conversion? Some 2.0 dCi engines reach 800,000 km; "look for buses with a good (reliable) engine." This FAQ highlights cheap vs optimal donor vans, engines, approvals, and light off‑road picks for 2–3‑seat builds. [Elektroda, adversus, post #17291890]
Why it matters: Picking the right base early prevents costly rebuilds, legal snags, and poor performance on rutted tracks.
Whats the best cheap vs optimal base van for a DIY motorhome?
For budget builds, consider Vivaro/Trafic L2H2 with 2.0 CDi or even 2.0 petrol for LPG. For optimal space, choose Boxer L3H2, with L4 as the roomy upgrade. Sprinter 212/312 are strong options if you find a good one; 313/316 CDI long bodies also fit camper layouts. Quote: “Boxer l3h2. Perfect would be l4.” [Elektroda, kakibara, post #17292043]
Which engines are known to last high mileage on road trips?
Users report the 2.0 dCi (chain‑timed) in Trafic/Vivaro can reach about 800,000 km when maintained. Prioritize documented history and reliability over peak power. Expert tip: “look for buses with a good (reliable) engine.” Verify service records and cooling systems before buying. [Elektroda, adversus, post #17291890]
L2H2 vs L3H2 vs L4: which size fits two people best?
L3H2 is the sweet spot for two, allowing a fixed bed plus galley and storage. L4 adds space for taller cabinetry, a larger bed, or bikes inside. If you keep it minimal, L2H2 can work for two with a convertible bed and compact kitchen. Quote: “Perfect would be L4.” [Elektroda, kakibara, post #17292043]
Are ex-ambulances worth buying for conversion?
Be cautious. Many ambulances were driven hard and idled long, leaving driveline and electrical systems tired. Expect worn interiors and wiring complexity. This is an edge case where low purchase price can hide high refurbishment costs. Quote: “These cars are tortured friend ...” [Elektroda, nici, post #17290039]
Should I consider a pickup instead of a van for rough tracks?
Yes, if forest tracks and rutted roads are routine. A Nissan or Toyota pickup offers better approach angles, ground clearance, and robust 4x4 options. You trade interior volume for off‑road capability and payload flexibility. Build a light camper box or canopy to keep weight low and center of gravity stable. [Elektroda, Romek T., post #17290288]
Do I need homologation or reclassification for my DIY conversion?
You may, depending on changes. Adding seats, altering occupant capacity, or fitting external electrical systems can trigger approvals. Before building, review the linked resources and your local rules to avoid inspection failures and fines. Plan the layout around what your registration class allows. [Elektroda, dizba, post #17290430]
Will diesel restrictions affect my travels in Europe?
Yes. Many cities restrict older diesels; targeting Euro 5 or Euro 6 helps future‑proof urban access. If you plan city sightseeing, factor this into the donor choice and registration year. Otherwise, you might face detours, fees, or outright bans in low‑emission zones. [Elektroda, Tommy82, post #17292430]
Is a Vivaro/Trafic a good compact base, and what about DPF years?
Vivaro/Trafic offers a good balance of size and running costs. Pre‑2009 models are noted as DPF‑free, simplifying ownership and avoiding clogging issues on short runs. The 2.0 CDi 114 hp suits light builds; 2.0 petrol on LPG cuts fuel costs further. Check rust and injectors. [Elektroda, kakibara, post #17292043]
What fuel costs should I expectdiesel vs LPG on the road?
Diesel on motorways was cited around 81.52/l, with higher prices in the south. LPG on a 2.0 petrol can be cheaper per km if tuned well. For long touring, compare your expected consumption and local fuel maps; the savings can fund campsite nights. [Elektroda, kakibara, post #17292043]
Is a refrigerated/isothermal van a smart donor for stealth camping?
Yes. Isothermal bodies insulate well, simplifying climate control. They also leave ample underfloor room for larger fuel tanks, batteries, fresh/grey water tanks, and heaters. Flat, clean walls speed up cabinetry. Remove redundant refrigeration hardware to save weight. [Elektroda, ArturAVS, post #17292644]
Is the VW LT35 with the 2.5 TDI R5 a reliable choice?
Yes. The LT35 2.5 TDI R5 is praised as an “armored” engine when maintained. Watch for body corrosion and seal the shell early in the build. If petrol + LPG appears, it can be economical, but such units are rarer. [Elektroda, dodek10, post #17293233]
How do older Sprinters compare (212/312/313/316) for a camper?
Sprinter 212 or 312 are desirable if you find a clean example. 313 CDI or 316 long wheelbase bodies give space for a fixed bed and galley. Inspect thoroughly for rust and drivetrain wear, then underseal before building. [Elektroda, kakibara, post #17292043]
Are Westfalia-style MPVs (Sharan/Alhambra/T4/Vito) worth considering?
Yes, for testing the lifestyle. Factory Westfalia variants offer a pop‑top, compact sink, and sometimes a gas cooker. They are great for short trips and learning layouts before a larger van build. Space is limited versus L3/L4 vans. [Elektroda, dodek10, post #17297401]
How many seats should I register for a couples build?
Two or three, depending on the front bench or individual seats you keep. Decide early, as seat count affects layout, weight distribution, and potential approvals. Keep belts and anchors factory where possible for compliance. [Elektroda, porywacz_zwlok, post #17290355]
How can I pick between candidates fast? (3-step method)
  1. Define must‑haves: seats (2–3), bed length, off‑grid goals, city access.
  2. Shortlist by drivetrain: proven engines, chain/belt, DPF presence.
  3. Inspect history: verify mileage, maintenance, and cooling/timing records; then test drive. Quote: “look for buses with a good (reliable) engine.” [Elektroda, adversus, post #17291890]
Are used food trucks easy to convert into campers?
They can be. A side‑opening wall eases indoor‑outdoor layouts, and you can add a sofa‑bed. Remove heavy kitchen gear to reclaim payload. Check for roof cuts, wiring, and compliance before purchase. Seal openings for weather and stealth. [Elektroda, Megawe, post #17291112]
