[Solved] Xiaomi Redmi 5A (2GB RAM, 16GB Memory) - No Range, Detached Element on Motherboard Found
zenon003 3474 3
  • Missing antenna-area component causing no signal
    #1 17289973
    zenon003
    Rate: 82
    Hello. I occasionally bought a Xiaomi redmi 5A phone with 2GB of RAM and 16GB of built-in memory. The phone has a slightly beaten touch which does not bother me and a defect in the form of no coverage. I do not know what was done, but after removing the flap and carefully examining the motherboard, I found a detached element. I mean, it looked like a detached element, or rather pads, after it was missing. I found photos of the motherboard and clearly this element should be there
    Element in the middle. It is in the vicinity of the antenna, which means that it probably has no range. What is a capacitor? Resistor? Can I bridge the connection or not?
    igor1516
    Help: 60
    Rate: 54
    Looks like a capacitor. Measure the adjacent value and apply the same.
  • #3 17291354
    zenon003
    Rate: 82
    What neighbor? I have bridged the connection and there is range.
  • #4 17306604
    zenon003
    Rate: 82
    Problem solved, I'm closing.
