Silicon Power SP S55 120GB SSD Showing as SATAFIRM S11: Boot Issue, Disk Initialization & Failure
jeremiw1 5373 2
  • SATAFIRM S11 drive cannot be initialized or tested
    #1 17290854
    jeremiw1
    Help: 24
    Rate: 19
    Please do not ban me, I am writing in this topic because I have a very similar problem.
    I have a Silicon Power SSD -> SP S55 120GB. Unfortunately, it is visible as SATAFIRM S11.
    The computer crashed the bluescreen while using the Internet, after restarting it crashes the message in the BIOS that it cannot boot from the device. After transferring the disk to another computer we have:
    - disk cannot be initialized in disk management, neither in GPT nor in MBR
    - when you try to run the disk surface test in HD Tune, it crashes after a few minutes of inactivity
    I am asking for help, is the disk damaged?
  • #2 17291334
    DriverMSG
    Help: 3984
    Rate: 4883
    Yes. The disk is damaged.
  • #3 17291524
    jeremiw1
    Help: 24
    Rate: 19
    Thank you, topic to be closed.
