[Solved] Goodram IRDM 120GB SSD - SATAFIRM S11 Issue - Disk Visible in BIOS but Inaccessible Files
damianos56 23676 9
How can I recover files from a Goodram IRDM 120GB SSD that is visible in BIOS as SATAFIRM S11 but cannot be accessed in DMDE?
Your SSD most likely has corrupted firmware, so the files are not normally accessible through DMDE and professional data recovery may be needed. [#17436761] [#17437615] [#17457507] If the disk was a system drive, first test it from a Live Linux environment to check whether it is still detected properly and whether any data can be read. [#17436837] In DMDE, open the device from the physical-disk list and check whether the first sectors are all zeros. [#17438287] This failure often makes the controller return incorrect data, usually only zeros, because the firmware has failed. [#17457507] Recovery can still be done only by bypassing the firmware problem with expensive specialist equipment. [#17457507]
  • #1 17436728
    damianos56
    Rate: 11
    There is a problem with the Goodram IRDM 120GB disk. The disk is visible from the bios, but under the name SATAFIRM S11.
    I can't get to files on disk via dmde. Please help.
    Goodram IRDM 120GB SSD - SATAFIRM S11 Issue - Disk Visible in BIOS but Inaccessible Files Goodram IRDM 120GB SSD - SATAFIRM S11 Issue - Disk Visible in BIOS but Inaccessible Files Goodram IRDM 120GB SSD - SATAFIRM S11 Issue - Disk Visible in BIOS but Inaccessible Files
  • #2 17436761
    SGdata
    Help: 125
    Rate: 181
    Probably corrupt firmware. Important data - DR.
    SGdata
    Spacerowa 90, Gliwice, 44-141 | Company Website: https://sgdata.pl
  • #4 17436771
    damianos56
    Rate: 11
    Yes, on screenshots it is connected as a second disk on another computer.
    Checking something in DriveLetterView on another computer?
    Which company do you recommend to recover your data?
  • #5 17436837
    pidar
    Help: 1569
    Rate: 3591
    No, because it was probably a system disk and after such a failure you should immediately check its detection (and possible access to data?) Under some Live Linux distribution.
    Currently (as the second) its capacity is still being detected :?:
    https://www.elektroda.pl/rtvforum/topic3268077.html#16045266
  • #6 17436841
    damianos56
    Rate: 11
    Yes, capacity is detected.
  • #7 17437615
    Łukasz_W
    HDD and data recovery specialist
    Help: 633
    Rate: 658
    As a colleague SGData wrote - a 99% firmware problem.
    HEX SERWIS
    Smołdzinska 2B/16, Kobysewo, 83-304 | Tel.: 530XXXXXX (Show) | Company Website: https://hex-serwis.pl
  • #8 17438287
    melanchel
    Help: 154
    Rate: 381
    In DMDE, it was selected from physical devices, browse if the first sectors are all zeros?
  • #9 17457507
    michal_aniol
    Help: 182
    Rate: 100
    They will be all zeros because the controller has firmware released and returns data incorrectly - usually only zeros. The FW problem can be bypassed and recovered, but expensive equipment is needed for that.
  • #10 17556422
    damianos56
    Rate: 11
    Thanks for the answers.
    Disk given for warranty, replaced with a new one.
    I have accepted the loss of data.
The discussion revolves around a Goodram IRDM 120GB SSD that is visible in BIOS but shows as SATAFIRM S11, rendering files inaccessible. Users suggest that the issue is likely due to corrupted firmware, which may lead to data loss. Recommendations include checking the disk on another computer and using tools like DriveLetterView and DMDE to assess the situation. It is noted that the disk's capacity is still detected, but the first sectors may contain zeros due to firmware issues. Ultimately, the original poster decided to replace the disk under warranty, accepting the loss of data.
