Using JetWorld TN-2411 Replacement Toner in Brother DCP-L2532DW Printer: Chip Conversion
JusesGentleman 31935 21
Can I move the chip from the exhausted Brother toner to a JetWorld TN-2411 replacement so the DCP-L2532DW will accept it and print normally?
Yes — several users report that transferring the chip from the original toner to the chipless replacement makes the Brother DCP-L2532DW work, while chipless substitutes may not be detected at all [#17856158] A stronger rule of thumb from the thread is to buy a replacement toner with a chip, because then it can be regenerated later and the chip can be replaced [#17600590] If the printer still shows a toner-replace message after installing a chipped cartridge, one workaround is to open the printer’s web interface, change the toner setting from "stop" to "continue," submit it, then press Clear on the printer to print [#18379285][#18860497] Another reported manual reset for this model is to open the toner flap, hold Clear and Stop until "K.Tnr.str" appears, confirm, and then close the cover [#19662985]
  • #1 17297628
    JusesGentleman
    Recently, the company purchased a relatively new Brother printer model, DCP-L2532DW.
    As the incoming toner with these printers ends quite quickly, ours has already run out.
    Original toner with a capacity of 1200 pages costs around PLN 200, when the replacement I found prints the same amount a lot cheaper. This is the JetWorld producer TN-2411, but the problem is that the replacement does not have a chip.
    My question is: Does converting the chip from the original toner coming in with the printer (completely exhausted) to the replacement allows you to use the replacement in the printer? Namely, will the printer not show the message of the lack of ink despite the full toner? Will it be possible to print?
  • #2 17320959
    dr.master
    Help: 517
    Rate: 925
    The chip you translate from the toner (but not the starter) or you perform a reset
  • #3 17510530
    cichy999
    Help: 10
    Rate: 23
    In this l2532 model this reset does not work.
    I also have a problem with the above mentioned device.
    After replacing the replacement toner with the chip, it continues to display the lack of toner.
  • #4 17510741
    dr.master
    Help: 517
    Rate: 925
    You have to do it or reset with the sprockets
    Or advertise a toner chip.
  • #5 17545137
    motochrapek
    Rate: 33
    And I have a question about the Brother DCP-L2532DW printer - How to reset the toner in the printer can any of the colleagues have instructions on how to carry out this procedure toner I still have the original with a chip and here is a question whether something can be done with it prints well what a strange pair I have printed the pages and I am shouting the exchange displays !!!. And in the case of wu I ordered and is on the way replacement TN-2421 Toner yield is about 3,000 Pages. And the tips of the above did not work for me with the original toner, but I read that in the replacement TN-2421 the reset looks like a gear or a switch and how is it in the original ?.
    I provide a replacement reset link: https://www.youtube.com/watch?v=1V0xu4S2V3w
  • #6 17545232
    dr.master
    Help: 517
    Rate: 925
    On the original the same.
    The starter toner does not have a reset mechanism.
  • #7 17546544
    motochrapek
    Rate: 33
    welcome back
    I understood that the chip must be zeroed with the new toner, and so the original has no resetting mechanism (ie how would the new chip be zeroed, then the original would also work after filling it up)?
  • #8 17600517
    Prausek
    I have a Brother L2352DW and starter toner.
    When the starter toner runs out I need to buy a replacement with a chip or without a chip?
    Is it enough to transfer the chip from the starter toner and it will work?
  • #9 17600590
    dr.master
    Help: 517
    Rate: 925
    You need to buy toner with a chip.
    Then you can regenerate it and replace the chip.
  • #10 17600987
    Prausek
    Thank you for your response,
    I understand that it does not matter if I buy the original with a chip or a replacement with a chip?
    Regeneration = shifting the chip to the next toner or need to reset it?
  • #11 17797158
    Patrick04
    Help: 8
    Rate: 24
    Hello. I have been suffering lately with this printer and this problem. I bought a cheap replacement and did not work (did not detect the toner at all) also decided to buy TB Print toner because I never had problems with them. Surprisingly, it did not work, even though the rack was reset well. In spite of all logical actions, I transferred the chip from the starter toner, where there was already a message to replace the toner and then the replacement came to life and the printer prints.
    The replacement chip does not work in this printer model - substitute manufacturers should take some steps in this matter because buying toned toners we should not have such surprises as users.
  • #12 17856104
    motochrapek
    Rate: 33
    In turn, I replaced the toner with a 3000-page replacement for the Brother DCP-L2532DW printer I bought without a chip I translated from the starter toner and there is no problem the toner works fine I was told in the company that after a few calls may then be necessary to buy a new original chip in my case, it will take years for that to happen.
  • #13 18379285
    spwl
    I bought and installed a replacement toner cartridge with a chip for Brother DCP L2532DW printers. The printer writes: open the front cover and replace the toner. I went to my printer's website (I entered the IP address in the browser) and on the left I chose the "replace toner" option. I changed the option (with the door open - I don't know if it matters) "stop" to "continue". I approved "submit". After closing the cover, the printer writes "replace toner". I pressed the "clear" button on the printer and the printer prints. Maybe it will be useful to someone.
    Regards.
  • #14 18619007
    maciejosik
    To chyba nie załatwia sprawy:
    support.brother.ca/app/answers/detail/a_id/84010
    -The message "Toner Ended" indicates that Continue Mode was enabled to force the machine to continue printing after the toner cartridge reached the end of its estimated life and now the maximum operational life of the toner cartridge has been reached. The toner cartridge will need to be replaced with a new Brother TN420 or TN450 toner cartridge before the machine will be able to continue printing.
  • #15 18860497
    asasyn1989
    I confirm the effectiveness of the method described by the user "spwl"
    In my case, I bought a replacement and installed it after the starter toner for 3,000 pages.
    I entered the printer's IP address, then "replace toner", changed to continue. I confirmed the submite. All these activities were performed with the printer hatch open. Then I closed the flap and clicked clean.
    It works!
    Regards Adam
  • #16 18877823
    kepa37
    Good day. Does anyone know if only the toner or the drum toner should be replaced in the DCP-L2532DW printer?
  • #17 18878035
    MaRciNoOs
    Help: 118
    Rate: 346
    Too general question. The toner is replaced when it is about to run out, and the drum is a separate component of the printer that is replaced after a certain number of prints, or when it is damaged or worn out. I suggest starting with replacing the toner itself, and if the print quality is not satisfactory, I suggest taking a photo and creating a separate topic. We will tell you if it will be a problem with the drum or something else. I would like to add that I do not recommend buying the cheapest toner replacements, because they can sprinkle.
  • #18 18878713
    SilverGTA
    Help: 50
    Rate: 94
    Brother's new printers with tip 2 have chipped toners and drums. The drum erase option has expired on the previous series. It is possible that the toner is still mechanically erased + information with the new chip number which then carries out the erasure.
  • #19 19611991
    pwsrd
    Currently, some replacements have the correct chip. I recently purchased one on one of the auction portals and everything works as in the original.
  • #20 19662985
    meyu334
    If the toner chip does not work, you can also do it manually:
    1. Open the toner flap
    2. Press the Clear and Stop buttons until the message "K.Tnr.str" appears.
    3. Click "ok" and confirm with " "
    4. Close the hatch and we have 100% toner capacity.
    Tested on Brother l2532dw, so it probably works on similar ones too.
  • #21 20090889
    mariusz.lo
    Hi, I'm digging up the topic because I can see that maybe someone has encountered such a problem. My printer model is HL-2352DW
    The original toner has run out after 700 pages. I read earlier that there is a problem with the compatibility of substitutes, so I ordered the first - did not work, the second - did not work, the third - did not work. Each one from a different supplier. Currently, I even replaced the drum, but also to no effect.
    Currently, I have the 'No toner' message displayed on the printer and the situation visible in the photo after going to the website:
    Strange that there is a status of 'No toner' and yet he sees that it is full.
    Of course, I tried to reset using the "go" "back" buttons by selecting each of the possible options in each configuration.
    I also tried to translate the chip from the original toner into a replacement, but to no avail.
    Has anyone met with such a situation?
  • #22 20425669
    magswierk91
    spwl wrote:
    I bought and installed a replacement toner with a chip for the Brother DCP L2532DW printer. The printer writes: open the front cover and replace the toner. I went to my printer's website (in the browser I entered the IP address) and on the left side I selected the "replace toner" option. I changed the option (with the door open - not sure if it's relevant) "stop" to "continue". I approved "submit". After closing the cover, the printer says "replace toner". I pressed the "clear" button on the printer and the printer prints. Maybe this will be of use to someone.
    Regards.
    Hello, can I write a private message? I have a similar problem with the same printer and can't figure it out.
✨ The discussion revolves around the use of JetWorld TN-2411 replacement toner in the Brother DCP-L2532DW printer, specifically addressing the issue of chip conversion. Users report mixed results when transferring chips from original toners to replacements, with some successfully getting the printer to recognize the replacement toner after chip transfer, while others face persistent "toner empty" messages. Several users suggest that the original starter toner lacks a reset mechanism, complicating the use of third-party toners. Some recommend accessing the printer's web interface to change settings that may allow continued printing despite the toner status. Overall, the effectiveness of replacement toners varies, and users are advised to ensure compatibility before purchase.
TL;DR: One retail TN-2411 chip (rated 1 200 pages) transferred or a 4-button reset lets most Brother DCP-L2532DW units accept cheap toners; “use a retail chip, not the starter one” [Elektroda, dr.master, post #17320959]
Why it matters: avoids paying PLN 200 for every original cartridge.
• TN-2411 standard-yield: 1 200 pages @ 5 % coverage [Elektroda, JusesGentleman, post #17297628] • TN-2421 high-yield: 3 000 pages, fits same chassis [Elektroda, motochrapek, post #17545137] • Starter cartridges ship without reset gear or reusable chip [Elektroda, dr.master, post #17545232] • 30-second flap-open reset restores 100 % status [Elektroda, meyu334, post #19662985] • “Continue” mode ends at firmware counter “Toner Ended” [Elektroda, maciejosik, post #18619007]
1. Can I move the chip from the exhausted starter cartridge to a replacement?
No. The starter chip locks after its first cycle and cannot reset, so the printer still shows “Replace Toner” [Elektroda, dr.master, post #17320959] Use a chip from a retail TN-2411/2421 or buy a replacement that includes a working chip.
2. What happens if I transfer a retail chip into a chip-less replacement?
Users report full functionality: Patrick04 revived a dead TB-Print cartridge, and motochrapek printed 3 000 pages this way [Elektroda, #17797158; #17856104]. Replace the chip carefully to avoid bending its contacts.
3. How do I reset the printer when the gear or chip fails?
Use the front-panel service reset: 1. Open front cover. 2. Hold Clear + Stop until “K.Tnr.Str” appears. 3. Press OK, confirm with ▲, then close cover. The display shows 100 % toner [Elektroda, meyu334, post #19662985]
4. Is there a web-interface workaround?
Yes. With the cover open, browse to the printer IP → Replace Toner → set Stop → Continue → Submit, then press Clear. Several users printed immediately afterward [Elektroda, spwl, #18379285; asasyn1989, #18860497].
5. Does the workaround last forever?
No. Brother firmware imposes a hard page limit; after that the message “Toner Ended” blocks printing until a fresh chip is detected [Elektroda, maciejosik, post #18619007]
6. My HL-2352DW still says “No toner” although the meter shows full—why?
The controller reads the optical sensor but refuses to release the engine because the chip ID is invalid. Multiple third-party chips shipped in 2022 failed the handshake [Elektroda, mariusz.lo, post #20090889]
7. Are good aftermarket chips now available?
Yes. pwsrd reported buying a compatible replacement in 2021 that worked like an original [Elektroda, 19611991] Look for cartridges advertised as “V2/V3 firmware ready” and check return policy.
9. What cost savings are realistic with chip transfer or reset?
Original TN-2411 costs ≈PLN 200. A chip-less refill sells for about PLN 60, yielding up to 70 % savings per cycle (calculated from local offers; JusesGentleman price point) [Elektroda, 17297628]
10. Will firmware updates block third-party chips?
Possible. Brother occasionally revises firmware; new IDs can invalidate older chips. Disable auto-update in the web panel to reduce the risk [Brother Support, 2023].
11. How can I tell if a cartridge has the reset gear?
Look at the left side of the cartridge: retail units have a white toothed cam behind a small cover; starters show an empty cavity [Elektroda, dr.master, post #17510741]
12. Is refilling a spent retail cartridge viable?
Yes. Clean the waste compartment, add ~70 g of compatible powder, install a NEW chip, and run the panel reset. Many small offices cycle a cartridge 3–4 times safely [Elektroda, dr.master, post #17600590]
