Brother HL - 1210WE - will not print after replacing toner with a replacement
sebstet 10701 4
  • #1 16908001
    sebstet
    I bought a replacement for Brother HL - 1210WE printer.
    Unfortunately, after replacement, a message appeared on the computer that this printer prefers only original toners ...
    The red light has started flashing and the printer is not printing.
    I am asking for help what to do in this case.
  • #2 16908212
    dasej
    Level 32  
    Help: 165
    Rate: 267
    You bought a tone with a bad Chip.
    What you can do is buy a better replacement or other Chip.
  • #3 16908762
    -dudus-
    Help: 44
    Rate: 42
    There are no chips in these toners, only resetters.
    It probably didn't work properly. So put it in the right position and put the toner back into the printer. The link shows how to set.
    https://www.youtube.com/watch?v=vXdr0JAoeZQ
  • #4 16909440
    sebstet
    The problem is that everything is as it should be in toner ...
    The cogs are set correctly.
    Don't I need to reset the printer or something?
    If so, please give me a hint.
  • #5 16910029
    Imprimarex
    Help: 57
    Rate: 204
    To reset the toner level, just set these cogs in the toner correctly. After inserting the toner into the printer, the cog rotates and resets the toner level.
    You do not need to reset the printer.
