Brother MFC-L2712DN Toner Reset: Replacing & Resetting Drum, Service Mode Access Troubles
Goodwayer 23382 6
  • #1 17527468
    Goodwayer
    Hello, after buying the above printer, I have a problem with resetting the toner after replacing it with a replacement. This can supposedly be done by resetting the drum, but there is no way I can enter service mode to do this. Most options from YouTube etc. do not work.
  • #2 17530127
    dr.master
    Help: 518
    Rate: 927
    You can clearly see in this screen how to enter the maintenance menu.
    Although for me this menu will do nothing :D
  • #3 17925477
    maacciek
    Rate: 24
    hello, did someone manage to run the replacement toner on this device?
  • #4 17925643
    dr.master
    Help: 518
    Rate: 927
    Was the reset with the flap open? :?:
  • #5 17927137
    leeart
    Help: 269
    Rate: 434
    There are chips on the toner in these printers, so that's why it won't work.
    LEE-CAN SERWIS
    PLAC CZERWCA 1976R NR 2 LOK 06, Warszawa, 02-495 | Tel.: 502XXXXXX (Show) | Company Website: serwisdrukarki.pl
  • #6 18704363
    maacciek
    Rate: 24
    always reset with the flap open
    there is another MFC-L2700DW model in the video, no problem with that
    However, in the MFC-L2712DN, the toner is with a chip,
    try another replacement for me it helped not everyone wants to cooperate.
    However, did anyone manage to reset the drum in this model?
  • #7 18993028
    jacusix
    Help: 6
    Rate: 118
    "Resetting the drum counter on the Brother MFC-L2712DN
    Turn on the device if it is turned off
    Open the front cover and leave it open
    Press the OK and UP buttons simultaneously
    Press the OK button to select the DRUM settings
    To reset the drum counter, press the UP button
    The drum counter should be reset, the front cover can be closed. "
    I obtained a working / proven method from the company from which I buy toners:
    "Reset Procedure:
    1. Start the printer
    2. Open the front cover of the printer
    3. Press the "back" buttons and the red cross at the same time - release - and immediately press the "back" button
    4. The reset menu should appear on the display
    5. Select "TNR-HC" for TN-2420 / TN-2421 enlarged toners, or "TNR-STD" for standard capacity toners
    6. Confirm reset
    7. Close the printer cover
    8. The printer should reset the toner
    9. Exit the reset menu with the menu button - "house"
    After completing the above procedure, the error should disappear and the printer should be ready to print. "
The discussion revolves around the Brother MFC-L2712DN printer, specifically addressing issues related to resetting the toner after replacement. Users report difficulties in entering service mode to reset the drum and toner counters. Several methods are suggested, including keeping the front cover open during the reset process and using specific button combinations to access the reset menu. It is noted that the printer uses toner chips, which may complicate the use of third-party replacements. A detailed reset procedure is provided, which includes steps to reset the drum counter and toner settings, confirming the reset, and closing the printer cover to complete the process.
