[Solved] Troubleshooting Whirlpool WIC 3T123 PFE Dishwasher: Error H and Unexpected Beeping
Kubeliks 45642 4
  • #1 17306000
    Kubeliks
    Rate: 21
    After selecting the program and closing the door, it starts working, after about 20 seconds it saves three times and after a while once, then a single squeal (the dishwasher does not work). After opening the door, the display shows " H "in the dishwasher on the bottom is water, after erasing the program and re-programming it first pumps out the water and starts work, again three beeps and one after a while one peels on the display H. However, after a few times (such resets) it starts to work normally for a few washes.
  • #2 17310753
    rychomuch
    Help: 142
    Rate: 693
    Probably a fault in the heating circuit.
    When opening and closing the door, the wire from the heater's power supply broke.
  • #3 17313874
    Kubeliks
    Rate: 21
    The dishwasher is fairly new - August 2017. Used only for visits of children and grandchildren, maybe two three times a month and the cable would already break? He has been working normally since the last post, but he will attack her many times and need to be re-activated several times.
  • #4 17314401
    mrice
    Moderator of Home appliances
    Help: 2214
    Rate: 6955
    In that case, if it's under warranty then report it to the site and let them look for a reason.
  • #5 17824329
    Kubeliks
    Rate: 21
    The problem was solved by the service, after the first visit, he ordered a driver panel and water measurement system in Italy, we waited 30 days for delivery, after replacing the water measurement system the dishwasher started to work correctly, the driver panel did not exchange, there was no need.
    Faulty water measurement module.
