Insignia 2009 A18XER - Error message U0140-71: ABS Module Issue & Troubleshooting Help
mail4skwarka 20607 10
How do I diagnose U0140-71 on a 2009 Opel Insignia A18XER, and is the ABS module likely damaged?
U0140-71 means lost communication with the body electronic module, or invalid data, on the module that stored the fault code, so it does not automatically point to a damaged ABS module [#16776006] Insignia models often log this kind of communication error when the battery is weak, so check the battery condition with a tester [#16776006] Also inspect all cables in the box above the battery for tightness, and note that the fault was described as an ABS-to-body-module communication problem or no communication with the body module [#16765188][#16776006]
  • #1 16764854
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    Can any of the forum members help me overcome this error?
    I suspect damage to the ABS module
  • #2 16765052
  • #3 16765188
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    Communication with ABS to the body module sends invalid data.
    Or no communication with the body module.
    MDI
  • #4 16765218
  • #5 16765354
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    It's not a Vectra C or a Zafira B ...
  • #6 16765383
  • #7 16765662
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    Only the engine had P0172 and P0300, mix composition and misfire, respectively.
    And the steering wheel rotation control shows nothing.
  • #8 16775784
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    I understand that a difficult topic ...
  • #9 16776006
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    The exact translation of this error from tisa
    U0140 71
    Lost Communication With Body Electronic Module, Invalid Data
    Of course on the module that registered this error ..
    Insignia often catches communication errors if the battery is weak (check its condition with a tester), check all cables in the box above the battery for tightness. Regards
  • #10 16776036
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    Registered ABS module
    The customer went to the service - I'll find out what and how they did ...
  • #11 18362092
    rozpadlodz
    Rate: 13
    @ mail4skwarka I have the same problem in my Astra J, can you write what caused the error at the client?
The discussion revolves around the error message U0140-71 encountered in a 2009 Insignia A18XER, indicating a communication issue with the ABS module. Forum members suggest that the error may stem from invalid data transmission between the ABS and body module, or a lack of communication altogether. It is noted that such errors can occur if the vehicle's battery is weak, and members recommend checking the battery condition and ensuring all cables are secure. Additional errors related to the engine, such as P0172 and P0300, were also mentioned, but no issues were found with the steering wheel rotation control. One user inquired about a similar problem in an Astra J, seeking further clarification on the cause of the error.
