[Solved] Opel Astra H 1.9 120KM '06: Error P0380, Glow Plug Relay Control Wiring Diagram Needed
m.marcin 25044 5
  • #1 17312241
    m.marcin
    Help: 24
    Rate: 71
    I need a glow plug relay control wiring diagram for ASTRA H 1.9 120ps 2006.
  • #2 17312395
    Ireneo
    Help: 747
    Rate: 2472
    Without a diagram, measure the basics.
    Translation of the error, you want help, give it something, nobody has a dtc table in their head
  • #3 17313395
    m.marcin
    Help: 24
    Rate: 71
    Did I ask for a translation of the error - no, because nothing will help me.
    I checked the candles - working.
    I need a diagram so I don't search for hours for wires.
    autoas
    Help: 571
    Rate: 3924
    Do you have a constant plus on the relay and plus on the ignition?
  • #5 17314279
    Ireneo
    Help: 747
    Rate: 2472
    Boy, give the translation and not P8000 because I will not look for what means 8000 and I have no memory for all errors. That's it, you want help, give exactly the description and not the error number, you think that there is no driving in your head or you want to look because you give riddle?
  • #6 17320717
    m.marcin
    Help: 24
    Rate: 71
    In my post I wrote clearly that I am asking for a diagram.
    So I ask: who can't read with understanding here?
    If nobody has - approx.
    For those interested, the error description:
    P0380 - Pre-heating device error - that is, to check the entire system up to the glow plugs.
    After a long search, I got to the point of failure - the wrong relay was installed, it only gave voltage to 2 candles.
    It would be easier and faster with the diagram, but unfortunately I didn't get any help.
    Thank you to all concerned
