Mobile Router vs. Smartphone-as-Router: Signal Strength Comparison for Huawei E5573 & Y5 II LTE
jarek21402140 17661 3
  • #1 17318490
    jarek21402140
    Conditionally unlocked
    I have a question, can a smartphone be used as a landline router? I just mean, will such a phone download the same signal as a mobile router, e.g. Huawei E5573? because I think phones are less connected to the network than a router. I am asking for some answer.
    Gives an example: The sim card inserted in the mobile router has a range of 3 lines on 5 LTe and works perfectly, while the same card e.g. in the Huawei Y5 II with LTE has 2 lines and I think this net works a bit slower or I think ... I think routers have stronger antennas.
  • #2 17319142
  • #3 17320600
    makosuu
    Help: 369
    Rate: 370
    Kraniec_Internetów wrote:
    For this, you can connect your phone via USB to your computer, and after the cable transfer the internet to a PC without a wifi card.
    Is a mobile router not? You can too.
    There is no major difference in speed or signal. However, the phone has no connectors for external antennas, E5573 has them. And the lines are uninteresting, the LTE signal has specific parameters.
  • #4 17320626
    matek451
    Help: 4352
    Rate: 5808
    Both are rather casual as a stationary LTE / LTE-A router. They are not recommended for 24/7 work. E5573 can be very bad, especially since it has antenna connectors, but in general the battery is not used for non-stop operation with the charger.
