JBL GO Speaker Issues: Not Turning On, Blue LED Not Working & Charging Problems - Solutions?
Mateusz 54 6981 5
  • #1 17319655
    Mateusz 54
    I have a problem today I connected the Jbl Go speaker to the laptop via a jack cable and listened to music at some time the speaker turned off did not turn on until after a while turned on and again I listened turned off and did not turn on so I connected it to charging the laptop and the diode signaling charging diminished until finally it went out and the blue diode does not burn the same also does not flash although now the speaker can be turned on and plays but this blue diode does not burn please help
  • #2 17319662
    icosie
    Help: 298
    Rate: 239
    I tried to read it, but unfortunately you can't understand "what the author meant".
    Please write again, but in Polish.
    Electronics to check, if you have a multimeter and a soldering iron then you can go for it, if not for service. NOTE: To play with the speaker you need at least some residual knowledge of electronics.
    Regards
  • #3 17319665
    Mateusz 54
    It cannot be turned off
  • #4 17319679
    icosie
    Help: 298
    Rate: 239
    It's under warranty? If so, give it back for guarantee because I still don't know what's going on.
  • #5 17319723
    Mateusz 54
    There is no guarantee.
    Anyone know what the speaker turns on but the blue LED is off? but when the connection for charging it lights up red and blue they are blinking together and when I disconnect it goes off what is it like?
  • #6 17320441
    Sanjose
    Level 32  
    Help: 181
    Rate: 228
    Mateusz 54 wrote:
    What?
    What what?
    Probably some module in the speaker has been damaged. Without diagrams and a factual description of the problem is to check what may be damaged.
