[Solved] Configuring Own Fiber Optic Router: Bypass ISP Restrictions, Port Forwarding & Dual Wi-Fi Setup
mexi_ 13905 8
  • #1 17322519
    mexi_
    Hello, this is my first forum post. My problem is that I have a router from my ISP at home, but I can't access it (I can't log into the configuration page). And I would like to have access to it, just to be able to forward ports or that kind of thing. I've already called the provider and they don't want to give access to the router. A fiber optic cable is directly plugged into this router and normally it has Wi-Fi and 4 LAN outputs, but it also has a telephone output (rj11) and two of the available LAN ports are configured for TV, because I have internet, TV and landline telephone on the fiber. And I would like to find out if I can somehow connect another router that would act as the main one, and in that one I would only have set-top boxes, phone and my router. The point is not that it only works and I have a second Wi-Fi, but that my network is completely configurable on this router without access to the one that is directly connected to the Internet.
    Thanks for the answers.
    Gutek699
    Ask the provider if he will agree to put the ONU (provider's router) into bridge mode. If so, you are buying your router, which will be your main router after proper configuration, and the ONU will act as a modem.
  • #3 17322530
    mexi_
    Thank you very much for your answer.
    I still have a question whether the television and the phone will then work normally when plugged into the provider's router?
  • #4 17322762
    makosuu
    Help: 369
    Rate: 370
    Ask the supplier. You may need to transfer everything to your hardware.
  • #5 17322831
    jprzedworski
    Help: 758
    Rate: 828
    The question is whether any redirection can be done at all. Fiber network providers usually assign a private IP address rather than a public IP address, so bridge will do nothing. You have to ask them for public. Sometimes it is possible for an additional fee.
  • #6 17322889
    geniusm
    Help: 70
    Rate: 49
    You can connect your router and have your network with which you will do whatever you want, but port forwarding will not work for the reasons given above.
    For example, if you want to have access from the outside, you need to buy a public IP, the port forwarding alone will not do anything (I have access to the operator's modem).
  • #7 17323621
    mexi_
    And if I bought an ONT Huawei Echolife hg8110h (there is a lan and telephone output in it) and connected it instead of the router from the provider, and the phone and my router to the ONT, then the router would configure two outputs for TV, everything would probably work. I would also buy these public IP. Does it even have the right to act? I don't know much about it, but it seems to me that such a system can work.
    makosuu
    Help: 369
    Rate: 370
    jprzedworski wrote:
    Fiber network providers usually assign a private IP address, not a public one
    Rather usually public.
    mexi_ wrote:
    And if I bought ONT Huawei Echolife hg8110h
    Not. You cannot use non-vendor equipment (unless the vendor approves it, which is rather doubtful). Ask them if they give a public address or need to be bought and what about the bridge mode.
  • #9 17323653
    mexi_
    Thanks for the help. Will contact the provider for "Bridge" mode and public IP.
The discussion revolves around configuring a personal fiber optic router to bypass ISP restrictions, specifically regarding port forwarding and dual Wi-Fi setup. The user is unable to access their ISP-provided router for configuration and seeks alternatives. Suggestions include asking the ISP to enable bridge mode on the existing router, which would allow a personal router to function as the main device. However, concerns are raised about the ISP's use of private IP addresses, which could hinder port forwarding capabilities. The user considers purchasing an ONT (Optical Network Terminal) model Huawei Echolife hg8110h to replace the ISP router, ensuring compatibility for phone and TV services while also acquiring a public IP address for external access. The importance of confirming with the ISP about the use of third-party equipment and public IP availability is emphasized.
