Opel Astra H - Location of the Z16XEP camshaft position sensor
lukpio3 44367 5
  • #1 17323722
    lukpio3
    Rate: 168
    Welcome,
    Today, while driving, the check lit up. After checking, error P0340 or a problem with communication with the camshaft position sensor. Deleting doesn't help. How to delete it and after firing it still appears. Twice while driving, this check was on, went out for a few seconds and then appeared again. My diagnosis is either a whack sensor, or connections to the ECU or the ECU itself. I have a request to you. Can anyone explain to me exactly where this sensor is located and how the connection to the ECU is carried out? I can't find it myself. I took off the timing cover but I can't see it. The same from the bottom of the channel, nothing can be seen. I have no idea where to look for him. Please help.
    The engine is Z16XEP.
    Here I have a view of this engine from the timing side but I can not see any sensor there
  • #2 17323771
    piotrekwoj1
    Help: 939
    Rate: 3392
    The program prompts under (between the wheel and the block) the right timing gear. Look for the plug or cable coming out of that place.
  • #3 17323773
    lukpio3
    Rate: 168
    The attached picture shows both timing wheels and the sensor is missing :( . After removing the cover, I can't see it anywhere.
  • #4 17323774
    ociz
    Help: 1378
    Rate: 3475
    You are not looking for this page. It's about the side of the box, at the end of the exhaust shaft.
  • #5 17323776
    lukpio3
    Rate: 168
    Oh, please, I wouldn't suppose in my life. And please, can you see it from above or rather from below from the channel?
  • #6 18516139
    Xsid
    Help: 5
    I warm up so that the post does not mislead. The sensor is located behind the wheel of the exhaust shaft as marked in red in the photo. You need to set the wheel to unscrew the screw between the spokes, then turn the sensor and pull it from the other side, behind the timing cover. A sensor is connected to the sensor, which makes it easier to find it.
    Greetings.
