[Solved] Terrace Roof: Fixing Bearing Beam on 20cm Styrofoam Facade without Trimming & Potential Issues
minimaxi 22239 5
  • #1 17328201
    minimaxi
    Rate: 119
    Hello, we have styrofoam g=20cm on the facade of the house and we want to build a terrace roof based on the wall, i.e. on a supporting beam screwed to the wall.
    1. is there a method to fix the beam on this styrofoam, without trimming?
    2. Does cutting a 20x20cm styro strip and screwing the beam through there have any negative effects? Greetings
  • #2 17328614
    kk.2000
    Help: 91
    Rate: 90
    1. I do not know a designer who would risk calculating such an invention.
    2. thermal bridge if proper insulation is not maintained.
    Buddy, if you are asking such a question, then your knowledge must not be too extensive in the field of structural design. I recommend having your idea (whatever it is) verified by a structural engineer.
    Note No. 2. The supporting structure must be attached to the supporting structure! Unless you're building a self-supporting structure. Then you attach it to the wall through polystyrene ONLY to seal the joint between the structures. Otherwise, the load-bearing structure cannot be attached to polystyrene, which is not a structural element!
  • #3 17328890
    minimaxi
    Rate: 119
    Buddy, since you're an automatic, it's probably normal that I have a distance to you.
    1. don't worry, just add supports or truss elements - that's the hint I expected
    2. well, the bridges used to be wooden, but dry wood, foam + 5 cm of styro and... "will you be satisfied?
  • #4 17328938
    vodiczka
    Help: 1185
    Rate: 4311
    minimaxi wrote:
    don't worry, just add supports or truss elements - such a hint I expected
    What supports? What truss? You asked if the beam can be fixed through polystyrene - the answer is NO.
    Assuming that the roofing of the terrace will be light and no one will walk on it except for cats, I would solve the problem as follows: Bars Φ 20 embedded in the wall through polystyrene and inserted into the holes in the beam. The beam is slightly pressed against the polystyrene.
    Whether such a solution will be possible, the assumptions need to be clarified; what dimensions of the roof, roof material and its weight, whether the roof "hangs" in the air or is supported in the corners not adjacent to the wall.
  • #5 17328989
    kk.2000
    Help: 91
    Rate: 90
    I expected such a hint
    I am not an automation engineer, although I employ automation engineers.
    Precisely because you "expected" someone to support your ideas, I made it clear that I did not support them.
    Why? So that you can distance yourself from your ideas. The distance to my competence is also correct!
    ___
    P.S. I designed a few structures myself and most often I evaluate structures that have already been designed. Hence my statement.
    P.S. When building a roof, you should take into account not only the cats, but also the snow load and resistance to wind pressure.
  • #6 17329212
    minimaxi
    Rate: 119
    Topic resolved positively. You can give spacers in styrofoam and then the beam on styrofoam can be cool. Regards
