Bmw x5 e53 4.4 2001: Trans Gearbox Error, Failsafe Proog Post-General Renovation
Gruby19891 15357 6
  • #1 17328871
    Gruby19891
    Hello, today, after starting the car, I got a trans failsafe proog message. I connected the car to the computer, 4 same errors popped up, unfortunately I do not know what because this computer did not show their name. The gearbox is after a general renovation in April 2017, the cost of repairing is 8 thousand. After resetting the errors, the gearbox did not enter the mode, it does not jerk, the gears change, it behaves perfectly at 140 and at a lower speed. I put out the car fired and so far the error does not come back. Could this be the cause of wetness and rainfall? Or that 2 weeks ago I had a problem with the current in the car escaping and my battery was dead and then the box also went into the mode but after restarting it returned to normal and today I had to use the computer to erase the error
  • #2 17329361
    lukasz12345678910
    Level 30  
    Help: 173
    Rate: 487
    Well, without error codes, you don't know anything anyway. You can guess. You'll need to read the error codes after you hit Safe Mode again.
  • #3 17331816
    Gruby19891
    Today I read an error and an error of one solenoid valve popped out. I called the workshop that deals with crates and says that it is possible that the driver of the box gets moisture due to raining and this is the cause of the error. I will add that this error appears when it is raining
  • #4 17332271
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1550
    Check the solenoid valve socket and plug for moisture. Bmw x5 e53 4.4 2001: Trans Gearbox Error, Failsafe Proog Post-General Renovation
  • #5 17333042
    Gruby19891
    To check it, you need to disassemble the crates?
  • #6 17333297
    lukasz12345678910
    Level 30  
    Help: 173
    Rate: 487
    No. You have to go under the car and remove the plug. See also the box controller, it is on the right side in the pit, if water is getting there.
  • #7 17333392
    Gruby19891
    Ok thanks for the hint
    Added after 1 [hours] 12 [minutes]:
    I have an appointment for a workshop on July 30th. Today the gearbox has entered the mode, it is still raining after starting the car and driving a short distance, I guessed it, I fired the car and the error disappeared.
✨ The discussion revolves around a BMW X5 E53 4.4 (2001) experiencing a "trans failsafe proog" message after starting the vehicle. The owner connected the car to a diagnostic computer, which revealed multiple error codes, although the specific codes were not displayed. The gearbox had undergone a general renovation in April 2017, costing 8,000. After resetting the errors, the gearbox functioned normally at various speeds, but the error reappeared under wet conditions. A workshop suggested that moisture might be affecting the gearbox's solenoid valve, particularly during rain. The owner was advised to check the solenoid valve socket for moisture without disassembling the gearbox, and they planned to visit a workshop for further inspection.
