[Solved] Toyota Rav4 2.0 D4D Warm Engine Power Loss at 2000 RPM: EGR, Turbine, SCV, or Catalytic Converter?
marco2255 17982 3
  • #1 17337385
    marco2255
    Help: 7
    Rate: 31
    Hello!
    The problem with Toyota 2.0 d4d check is not lit, the most noticeable is on a warm engine, at 2000,000 rpm, e.g. at 3rd or 4th gear, the car loses power, the turbine after regeneration is about 1500 km, I cleaned the EGR valve, nothing helped, I unplugged the flow meter, nothing it helped, while driving, when he has such a mule, you can hear the whistle of the turbine, but with the removal of gas, the whistle decreases. I do not know what to do next, whether to clean the catalytic converter or to typically replace the SCV.
    maybe someone had similar symptoms, I would be very grateful for advice.
  • #2 17337484
    kamyczek
    Help: 394
    Rate: 573
    You checked the tightness of the boost system, the pressure. It could be a fuel pressure problem as well as a boost pressure problem. When the car gets weaker it smokes. There can be a dozen faults and the effect is the same ... First, a computer and reading errors and parameters, then some logical diagnosis.
  • #3 17351904
    marco2255
    Help: 7
    Rate: 31
    The only positive reaction occurs after thorough cleaning of the flow meter, the car comes back to life and works perfectly.
    After connecting the computer, there are errors:
    P0100
    P1115
    P1228
    I am afraid of error P1228 the most, is it possible that the SCV saucers are damaged? could the car only occasionally catch a bug?
    EDIT:
    The reason was the SCV valves after replacing the car like new.
  • #4 17616805
    marco2255
    Help: 7
    Rate: 31
    The reason was the SCV valves, after replacing the car like new
