Passat B6 - does not close the trunk lid and do not work wipers + spray
Tomaszo22 18438 6
  • #1 17340595
    Tomaszo22
    Rate: 8
    Hello, today the trunk lid in my belt has stopped closing, it does not latch at all, and the wipers do not work, so I would like to ask if someone has encountered a similar problem and give me an idea for repair
  • #2 17340700
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Grommet to check if the wires are cracked.
  • #3 17340927
    Tomaszo22
    Rate: 8
    I have just disassembled the lock, there is a tin spring in the motor that drives the motor, it is cracked, I think that it does not bounce and the lock is open all the time
  • #4 17341016
    Gredier
    Level 4  
    As for the wipers:
    - blown fuse
    - seized motor
    - rotten cables
    Most often it was the motors that blurred, because the aluminum oxidizes and tarnishes, after dismantling, cleaning and lubricating, they should run like new.
    As for the washer, check the motor, it may walk, but not generate pressure to deliver the liquid, it may also not walk at all, possibly a broken hose, or clogged tips (those on the hood through which liquid is flowing onto the windshield)
  • #5 18397563
    natis04
    Rate: 33
    Hello. Have you solved the problem because I have the same and I'm looking for the cause?
  • #6 18397596
    Aleksander_01
    Help: 1167
    Rate: 3432
    You solved the case of the lock in an exemplary manner, you will repair it, buy a stimulant or a new one and the problem is gone.
    As for the wipers, check the fuses, the hood must be closed (the light on the board is off), see if there is 12 V to the wiper motor, and it is best to diagnose this VCDS and everything will be clear.
    The question is - do you have xenon, if so, original or added.
  • #7 19523731
    natis04
    Rate: 33
    If the hatch is not closed, the wiper does not work.
The discussion revolves around issues with a Volkswagen Passat B6, specifically a trunk lid that fails to close and non-functional wipers. Users suggest checking for cracked wires, a broken tin spring in the lock mechanism, and potential causes for the wiper malfunction, including blown fuses, a seized motor, or damaged cables. Recommendations include inspecting the wiper motor for functionality, ensuring the hood is closed to activate the wipers, and using diagnostic tools like VCDS for troubleshooting.
