Passat B6 2006 Sedan: Self-Opening Hatch Issue, Micro Contact, Comfort Module Location
vince82 8622 6
  • #1 16264205
    vince82
    Rate: 23
    As in the subject, the trunk opens itself.
    Micro contact in the stamp eliminated, the lock itself looks ok. Wires at the grommet approx. The customer noticed that if the battery is weak it opens more often, there are no errors in the comfort module.
    Could the above module fail ???
    Where is the comfort module located?
  • #3 16266717
    vince82
    Rate: 23
    Not that flap. The grommet first went to check is ok.
    The three wires reach the flap lock +, - and the signal like a plug is plugged into the flap lock, the switch closes the circuit and the voltage disappears, it appears only after closing the lock.
  • #4 16266751
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6417
    vince82 wrote:
    the customer noticed that it was like a battery
    In such a car there can not be a weak battery, what a wheelbarrow is this again.
    Second, unhook everything except the actuator from the flap.
  • #5 16266758
    vince82
    Rate: 23
    One more thing puzzles me on the cable where is +12 in the lock after starting the engine the light is flashing ???
    what does everything mean
    He agrees with this weak battery only under the charger where it was charging also opened
  • #6 16274722
    vince82
    Rate: 23
    Everything leads to the driver in the driver's door, also the grommet in the driver's door has to be checked.
  • #7 16416782
    vince82
    Rate: 23
    I ended up replacing the comfort module and resolved the problem.
✨ The discussion revolves around a self-opening trunk issue in a 2006 Volkswagen Passat B6 sedan. The user has ruled out a faulty micro contact and lock, noting that the problem seems to worsen with a weak battery. Responses suggest checking the wiring and grommet in the driver's door, as well as the comfort module, which is suspected to be the source of the malfunction. Ultimately, one user resolved the issue by replacing the comfort module.
