Elektromet WJ Mister 80 (2016 model) - Magnesium Anode Replacement Issues
lukaszuk1995 15768 1
  • #1 17348467
    lukaszuk1995
    Hello, I have a problem with the replacement of the magnesium anode in Elektromet WJ Mister 80 liters, year 2016. According to instructions, the anode can be accessed after removing the heater cover, however - in this model the heater cover cannot be unscrewed, you can only unscrew the hexagonal plug that holds the heater - but neither the knob nor the anode will pass through the hole.
    Instructions: https://instalacjeb2b.pl/files/1271,instrukcja_WJ.pdf
    Question for you - did you have contact with this heater? The only salvation is to download it from the wall and access the chamber "from above"?
  • #2 17348481
    badyl00
    Level 30  
    Help: 221
    Rate: 300
    Maybe the heater will not pass because it is all killed by stone? Page 10 points 5 instructions below:
    • instr_ WJ standard, Mister, Venus I z korkiem 02 15.pdf (683.91 KB) You must be logged in to download this attachment.
