Volvo FH 460 (2010): Adblue Heater No.2 Error - Resistance and Voltage Measurements
lukasz56 14427 8
  • #1 17351018
    lukasz56
    Rate: 98
    Hello, I have a problem with the adblue heater error No. 2 in Volv FH 2010. The computer shows a heater defect, after measuring it, the resistance is 7 ohms (the tolerance of this cable from what I read is from 8 to 15 ohms) and now the question is whether with such a small the difference will cause an error? I measured the voltage on the cubes of this cassette from which all the wires to the heaters come out and there is about 24 volt everywhere and there is 15 volt on the cube from the heater No. 2 (the key is turned on the ignition) and after starting the car, the voltage on the black heater cube number 2 drops to around 7 volts. Is this normal?
    I dismantled the cassette that is next to the adbue pump, but all the wires are visually ok. I do not want to replace the heater blindly because I feel that I will throw money down the drain and the problem is somewhere else.
    Will someone tell you how to bite it?
  • #2 17351297
  • #3 17356934
    gun20
    Rate: 21
    I would more consider why scr wants a heater during the summer vacation. Maybe one of the temperature sensors is out of order, or there is moisture in the cassette
  • #4 17356966
    Dagomir
    Help: 42
    Rate: 191
    Gun 20 scr will want a heater during the holidays because the system checks the operation of all elements, even though it will not use it for heating. A damaged heater will not limit the power in summer, etc., while in winter it is possible.
  • #5 17357181
    lukasz56
    Rate: 98
    Can I connect the working heater No. 3 to the heater No. 2 socket, which displays the error? (it is known that the cubes do not fit, but I would fasten them with crocodile clips to the plug) If this would eliminate the error, I would be sure that the heater No. 2 should be removed and carefully traced for damage to the braid. Not the adblue driver?
  • #6 17359355
    Dagomir
    Help: 42
    Rate: 191
    You cannot damage the module because it has internal protections. On the other hand, replacing the heaters may not give the expected effect in the form of wandering or disappearance of the error. You need to know that the heaters have different lengths, therefore their resistances are different, swapping places may not facilitate the identification of the fault.
  • #7 17359455
    Under_Pressure
    Help: 57
    Rate: 354
    Disconnect the heater near the module and ring the meter.
  • #8 17359808
    Dagomir
    Help: 42
    Rate: 191
    There, checking the meter buzzer will do nothing. Ok take a good meter and do the resistance measurements again:
    Heater 2 (yellow wire, black pin) 8-15 ohm
    Heater 3 (red wire, gray contact) 8-13 ohm
    Heater 4 (white wire, blue contact) 11-15 ohm
    You have already taken the measurements, but spray the plugs with the contact and check everything again.
  • #9 17360858
    lukasz56
    Rate: 98
    I will check the resistance of all heaters once more, but I will buy a better meter because I checked the usual one for PLN 30. Of all heaters, only two emit an error because it has a resistance of 7 ohms, which means that it does not fall within the range of 8-15. I will measure and write. Thanks in advance for all suggestions and hints, because in my area, the adblue repair is a month waiting for the guy to do this.
The discussion revolves around an AdBlue heater error (No. 2) in a 2010 Volvo FH 460. The user reports a resistance measurement of 7 ohms for the heater, which is below the acceptable range of 8-15 ohms, and queries whether this discrepancy could trigger the error. Voltage measurements indicate 24 volts at the heater's connector, dropping to 7 volts when the vehicle is started. Various responses suggest checking the wiring and connections, considering potential issues with temperature sensors or moisture in the cassette, and the possibility of swapping heater connections to diagnose the problem. It is advised to use a quality multimeter for accurate resistance measurements and to inspect the heater for physical damage.
