[Solved] VW Passat B5: Guide on Dismantling and Fixing the Passenger Compartment Flap Handle
yogi009 14301 4
  • #1 17358597
    yogi009
    Help: 848
    Rate: 2655
    A friend pulled out the handle opening this compartment (it was not locked), I thought to disassemble this flap and do some fixing of this handle. There are two metal pins that form the horizontal axis of the flap operation. I think the plastic fastenings of these bolts have broken off in the flap. Well, but first you have to somehow dismantle this flap and tear everything around :-)
  • #3 17358916
    yogi009
    Help: 848
    Rate: 2655
    Thanks for these topics, I already have some knowledge, but there are many photos invisible, and I do not know how to remove / remove the "door" from the clipboard. Ew. how to disassemble the entire storage compartment, as if the flap itself could not be removed.
  • #5 17362882
    yogi009
    Help: 848
    Rate: 2655
    Many thanks, after watching these few photos, the topic turned out to be quite simple (though a bit time consuming). In order for something to remain for posterity, I will only write that if the handle of the clipboard is damaged, it must be completely removed by unscrewing the 7 torx20 screws and disconnect the cube from the light illuminating the clipboard. Then remove the flap itself and separate it with a flat, wider screwdriver (unfortunately the plastic welding points must crack). The repair itself is simple, put the axles in place and glue their outermost (outer) distals so that they do not fall out again. Then we need to glue the two parts of the flap by squeezing them thoroughly (I used clamps and two spring clamps. Finally, the assembly of the flap and the entire storage compartment in the car. They could have designed it differently to simplify the service of such a small handle, but German technical thought recognized that this would be the best way.
    Thank you for the material!
