Comparing Sony VTC5A and VTC5 Cells: Discharge Current and Value Analysis
Kubcioo 17811 9
  • #1 17360450
    Kubcioo
    Rate: 10
    Hello, what is the difference between Sony VTC5A and VTC5 cells. Which has a higher discharge current? Is it worth paying extra to VTC5A?
    kacpo1
    Help: 273
    Rate: 156
    Different sellers provide different parameters regarding the Charging / Discharge Current, because in fact, such cells have a much, much higher maximum discharge current than specified by the manufacturer. But using them under higher loads may result in, among other things, a reduction in capacity, total cell damage and even an explosion.
    Safe current for VTC5 is 20A and for VTC5A is 35A
  • #3 17360689
    Kubcioo
    Rate: 10
    Is it better to choose VTC5A? 35A discharge current?
  • #4 17360769
    kj1
    Electrician specialist
    Help: 278
    Rate: 848
    It depends if you need so much electricity ...
  • #5 17360777
    Kubcioo
    Rate: 10
    Under the rc model for trial. I prefer to have more electricity.
    Added after 11 [hours] 51 [minutes]:
    Which link is better to choose? Which one is better? VTC5A or VTC5A?
  • #6 17363864
    kacpo1
    Help: 273
    Rate: 156
    I would choose VTC5A, although VTC5A also has interesting parameters.
    Seriously, estimate what current you will need, and choose such cells.
  • #7 17363874
    Kubcioo
    Rate: 10
    I would rather have a supply of amps than cook the cell. Is VTC5A more efficient?
  • #8 17363895
    kacpo1
    Help: 273
    Rate: 156
    In post # 2 you have the answer.
    "Safe current for VTC5 is 20A and for VTC5A is 35A"
  • #9 17363918
    Kubcioo
    Rate: 10
    And do you know any link catalog what everything is described about the link? Each seller gives different parameters.
✨ The discussion centers on the comparison between Sony VTC5A and VTC5 cells, focusing on their discharge current capabilities. The VTC5A has a safe discharge current of 35A, while the VTC5 is rated at 20A. Users express a preference for the VTC5A due to its higher discharge capacity, especially for applications requiring more power. However, it is noted that using cells beyond their specified limits can lead to reduced capacity and potential damage. Participants also seek reliable sources for specifications, as different sellers provide varying parameters for these cells.
